[HOW-TO]Spoon Twin Block Caliper Install on 4x100 with 10" Stock Brakes
Brake install time! I’m going to make a write up how to do this installation because this is for one, a brake setup for the 5lug Type R’s going on a 4lug 10" Rotor Civic/Integra; two, there isn’t any good write ups on how to do this for others to read.
First of all, you need the parts to do the job.
Parts:
1. Spoon Calipers
2. (4) 1mm washers
3. Type R Brake pads
4. Rotors, I used the 2007 Mini Cooper NON S version. You can also use redrilled 94-96 Prelude VTEC rotors.
5. Brake fluid
6. (Optional) 3mm rotor spacers, You need these when you are using the Prelude rotors
The first step you want to do after you take the wheel off is unbolt the brake line from the knuckle. There should be (2) 10mm bolts holding it on. This will free up the line so you have more room to work on.
Once the line is unbolted, take off the caliper with (2) 17mm bolts and slide off the rotor. Once those are off, you will need to grind off the “ears” of the dust shield. The calipers are much wider and you need these removed to have clearance for the calipers.
Place the rotor on and secure it with lugnuts. Since I am using the 2007 Mini Cooper NON S rotors, I don't have to use the 3mm rotor spacers. But, if you decide to use the Prelude VTEC rotors, you will need to place the space on the hub, then place the rotor over it.
Grab you caliper bolts and the washers, you will need to put the washer between the knuckle and the caliper.
Bolt the caliper up and tighten to spec. once you have the caliper on, unbolt the brake pad stays. This consist of a (2) 10mm nuts and (2) long bolts with allen heads. Once loosened, slide the bolts out.
Before putting on the pad, break off the metal tabs.
When installing the pads, I would recommend shaving the pad compound material down 1mm. I didn’t do this and my pads were rubbing against my rotors so bad, they were over heating my fluid. I’m not sure if this is the case with all pads, but just a precaution.
To install the pads, you just slide them in through the top of the caliper.
When you put everything back together, please… Anti-Seize the bolts! This will make your next brake job even easier.
Once you bleed the brakes (back side to front side on multipiston calipers), you should be almost all done! Some people may have to bleed another time just in case. But that’s all to it really, make sure everything is bolted up tight to spec, put on your wheels, and go break in those pads and rotors!
Parts:
1. Spoon Calipers
2. (4) 1mm washers
5. Brake fluid
thabao
Suspension & Brakes
25
Aug 11, 2014 06:19 PM
thabao
Oct 11, 2012 09:37 PM
