Oil leak coming mostly from above oil pan lug....
Old Oct 9, 2012 | 12:40 PM
Seankuhh1023's Avatar
Default Oil leak coming mostly from above oil pan lug....
So I've always had a very very minor oil leak on my 95 gsr so I put a cardboard below the oil pan on the ground so see where most of it would be coming from so when it leaks it leaves spots in random places from my oil pan with about 5-6 drops over night. I didn't think too much of it and I let it be for about another but last night when I got home I dropped my keys and saw that my car was leaking a grip. When I looked under my car no jacked up I saw most of it coming from above the oil pan lug and over time it traveled down along my cat and of course I started to smell burnt oil and saw smoke arising from under my hood. I haven't really jacked up my car yet to see where it could possibly be coming from and I first thought maybe its my oil filter or my oil pan gasket since all around my gasket it's wet with oil. I'm currently waiting for my car to cool down to jack it up find the source and replace the gasket and tighten the filter if needed. Anyone have any ideas? Really could use any thoughts before getting my hands dirty and last thing it only leaks when the car is running and after its turned off and the oil is hot. Thanks guys
Old Oct 9, 2012 | 06:55 PM
1998GsRIntegra's Avatar
Default Re: Oil leak coming mostly from above oil pan lug....
Well the only thing I can tell you with out having a picture is that it's a pressurized leak and the laws of gravity still apply so start looking high. Good luck.
Old Oct 9, 2012 | 08:57 PM
guyver13's Avatar
problem solved
Old Oct 10, 2012 | 06:59 PM
KtHaNxBai's Avatar
what was it?
Old Oct 11, 2012 | 07:45 AM
Originally Posted by KtHaNxBai
what was it?
Lmfaooo somehow my oil filter became loose. Funny to say yes I'm dumb but I do an oil change every 2500 and I'm about 300 miles away from my next oil change so after 2k miles my stupid filter became lose -___- my oil pan is a bit wet too along the gasket area so ill change that soon. Js so many bolts!!!
Uljima
Jun 3, 2015 06:17 AM
MumBleZ_94gsR
May 30, 2009 03:26 PM
sheeve
Oct 1, 2005 09:56 PM
Pinhead
Jun 9, 2002 01:53 PM
