f22 motor with a h22 trans ?
Old Oct 9, 2012 | 06:08 AM
civicsupreme's Avatar
Default f22 motor with a h22 trans ?
will a h22 trans bolt up to a f22 motor ? and drop no problem ? also is the trans and motor mounts the same as well ? sorry if I posted in the wrong thread I'm new .
Old Oct 9, 2012 | 03:57 PM
GhostAccord's Avatar
Default Re: f22 motor with a h22 trans ?
Yes.
What chassis?
Not exactly!
If you are putting this into a Civic you would bolt the H trans to the F block and use a set of off the shelf Civic H swap mounts.
Old Oct 15, 2012 | 07:17 AM
Thanks ghost accord ! I saw your turbo build on here which is very nice ! But i have another question would a f20b piston fit on a h22 connecting rod ? Ive read you can't use a stock f22 piston because the wrist pin differences one being pressed and one floating .
Old Oct 15, 2012 | 07:22 AM
honda_12V's Avatar
Hello,
A little bit of high jacking.
Will a U2Q7 H22 trans fit a F23 in a accord chassis? On H mounts?
Regards
Old Oct 15, 2012 | 11:41 AM
What block and crank are you using?
IIRC the piston from the DOHC F20B also uses a floating wrist pin.
Old Oct 15, 2012 | 06:03 PM
Well I haven't figured it out yet I was thinking of using a f22b block with the same crank with the h22 rods and f20b pistons ? But I don't think that would work I'm not looking to do a crazy build I just wanna try and build something for the hell of it .
Old Oct 15, 2012 | 06:10 PM
Those rods are too long for the 95mm stroke crank and the compression height of the stock F20B pistons. The piston would be sticking out of the hole 2mm (0.079"). You could use them and run a custom 0.060" - 0.080" head gasket. Or you could get a set of custom 29mm compression height pistons....$$$$
Or
There are a couple hybrid builds using an 86mm bored F22 block and K20 pistons....... or you could get an F23 block and run K20 pistons...... Check out the hybrid forum, there are a couple F series builds in there that might interest you!
92hondalude
Apr 20, 2006 09:38 PM
singlecamkilla
Mar 5, 2004 03:57 PM
tcb18c5crx
Jun 12, 2003 09:29 AM
