Wilwood brake master to stiff?
Old Oct 8, 2012 | 04:23 PM
ekcoupeh22's Avatar
Default Wilwood brake master to stiff?
ok so I INstalled a chase bays brake booster delete which is a wilwood master now that is only powering my front brakes. The rears are on a staging brake. I bled the front calipers out and then tested the pedal and it's rock solid. I mean there is maybe an inch of play if that before it's like pushing against a wall. I have not driven the car cause of a problem with my coil on plug setup. But does this seem normal? Or is it to stiff?
Old Oct 8, 2012 | 04:30 PM
h22crxpwr's Avatar
Default Re: Wilwood brake master to stiff?
never seen the chase bays one.. but i used the kens kustom chassis one and it was stiff as all hell. had to do a lot of adjusting to get it to the right spot.
I took it to the dyno and had to disconnect the brakes entirely because it was locking up on the dyno.. hahaha
after i got the adjustment right it wasnt too bad. but its defintely not like it is with the booster.
Old Oct 8, 2012 | 04:38 PM
ekcoupeh22's Avatar
Did you have almost no pedal? Mines like a rock almost at the top if there is an inch of play...how do you adjust it to loosen it up? At the pedal?
kirlous k
Suspension & Brakes
11
Jun 16, 2018 04:18 PM
ekcoupeh22
Suspension & Brakes
25
Oct 13, 2012 12:01 PM
4DoorCivic1
Jun 4, 2012 08:43 PM
SlammedEG6
Aug 16, 2010 12:46 PM
ShortBusTechnologies
Jan 20, 2006 08:24 PM
