'96-'00 civic parts/CDM EL cluster/CDM OEM airbag delete tray/Integra parts/NGK/Apexi
cleaning out our garage, a few parts that some of you may want:
- '96-'00 Civic hatchback OEM EK9 power folding mirrors, will fit on '96-'00 civic coupe's as well. does not come with switch and relay, mirrors only. - SOLD!
_DSC0429 by bonspeed07, on Flickr
- '96-'00 Civic D series rear transmission bracket, a/c compressor bracket, front transmission bracket - all for $20
- D16y7 manual transmission ECU(P2E)2 available - $30
- '96-'00 Civic ABS control unit - $30
Spoon/Vision rear upper strut bar - SOLD!
- OBD0 B16 intake manifold with injectors, fuel rail, fuel pressure regulator, throttle body, harness(missing vtec pressure switch, vtec solenoid, knock sensor wires), no IAT sensor and IACV sensor - SOLD!
- '90-'93 Acura Integra OEM airbox - $20
- Brand new B series cable type release bearing - $30
- '96-'98 Civic Si(CDM)EX(USDM) manual transmission ECU OBD2A(P2P) - $50
- '96-'00 CDM Acura EL gauge cluster(M/T) - SOLD!
http://www.flickr.com/photos/51799266@N02/7792464702/http://www.flickr.com/photos/51799266@N02/7792464702/ by bonspeed07, on Flickr
-'96-'00 Civic CDM OEM airbag delete tray(Type K)with brackets - SOLD!
- Brand new HKS air filter - SOLD!
http://www.flickr.com/photos/51799266@N02/8385590012/http://www.flickr.com/photos/51799266@N02/8385590012/ by bonspeed07, on Flickr
- '96-'00 Civic/CRV/Prelude JDM side marker w/sockets and bulbs(3 set available) - SOLD!
http://www.flickr.com/photos/51799266@N02/8385588838/http://www.flickr.com/photos/51799266@N02/8385588838/ by bonspeed07, on Flickr
- '99-'00 Civic Si(CDM) EX(USDM)coupe floor harness, if you want to convert your CX,DX hatch/coupe to power windows,locks,mirrors you'll need this harness to do the conversion - SOLD!
- '92-'95 Civic JDM audio console, comes with all the brackets to install and shifter surrond - SOLD!
- '96-'00 Civic gauge cluster w/rpm(m/t)reads 204,000km - SOLD!
- Tenzo R oil pressure gauge - SOLD!
-'96-'00 Civic CDM OEM airbag delete tray(Type F)no brackets - SOLD!
_DSC0905 by bonspeed07, on Flickr
_DSC0906 by bonspeed07, on Flickr
- '99-'00 Civic cup holder insert/reducer - $15/each
_DSC0445 by bonspeed07, on Flickr
_DSC0446 by bonspeed07, on Flickr
- '96-'98 Civic CTR EK9 OEM grill - $180
_DSC0901 by bonspeed07, on Flickr
_DSC0903 by bonspeed07, on Flickr
- '96-'98 Civic JDM EK4 SiR headlights, does not come with headlight bulbs but comes with city lights sockets and turn signal sockets, no broken/cracked tabs. passenger side has a small spider web crack on the upper portion of the chrome housing(pictured) but doesn't affect lighting and not really noticeable unless you look close, driver side is showing some haze on the upper part of the lense(also pictured) but other than that the headlights are in good condition - $180 plus shipping/paypal
_DSC0911 by bonspeed07, on Flickr
_DSC0914 by bonspeed07, on Flickr
_DSC0915 by bonspeed07, on Flickr
_DSC0916 by bonspeed07, on Flickr
_DSC0917 by bonspeed07, on Flickr
_DSC0925 by bonspeed07, on Flickr
_DSC0927 by bonspeed07, on Flickr
_DSC0931 by bonspeed07, on Flickr
-'96-'00 Civic CDM OEM airbag delete tray(Type K)with brackets - $60 SOLD!
_DSC1554 by bonspeed07, on Flickr
_DSC1555 by bonspeed07, on Flickr
- '97-'00 Acura 1.6 EL power mirror switch with heat function(black)with pigtail - $50
_DSC1559 by bonspeed07, on Flickr
_DSC1560 by bonspeed07, on Flickr
- '97-'00 Acura 1.6 EL gauge cluster(a/t) reads 164,096 km's not miles, lights up amber, direct bolt-on to any '96-'00 civic and first gen. CR-V, small bubbles showing by fuel and temp gauge area and RPM hence the price - $120 - SOLD!
_DSC1563 by bonspeed07, on Flickr
_DSC1565 by bonspeed07, on Flickr
_DSC1566 by bonspeed07, on Flickr
- '96-'00 Civic gauge cluster(m/t) reads 272,989 km's not miles - $60
_DSC1568 by bonspeed07, on Flickr
- '97-'00 Acura 1.6 EL side mirrors, power mirror manual folding with heat function(needs switch, harness and relay for heated mirrors to work) comes with inner cover, direct bolt-on to any '96-'00 Civic sedan - $180
_DSC1569 by bonspeed07, on Flickr
_DSC1574 by bonspeed07, on Flickr
_DSC1575 by bonspeed07, on Flickr
_DSC1576 by bonspeed07, on Flickr
all prices does not include shipping and paypal fees.
Contact:
- call or text @ 204-898-0502 or pm
_DSC0429 by bonspeed07, on Flickr- '96-'00 Civic D series rear transmission bracket, a/c compressor bracket, front transmission bracket - all for $20
_DSC0906 by bonspeed07, on Flickr- '99-'00 Civic cup holder insert/reducer - $15/each
_DSC0446 by bonspeed07, on Flickr- '96-'98 Civic CTR EK9 OEM grill - $180
_DSC0903 by bonspeed07, on Flickr- '96-'98 Civic JDM EK4 SiR headlights, does not come with headlight bulbs but comes with city lights sockets and turn signal sockets, no broken/cracked tabs. passenger side has a small spider web crack on the upper portion of the chrome housing(pictured) but doesn't affect lighting and not really noticeable unless you look close, driver side is showing some haze on the upper part of the lense(also pictured) but other than that the headlights are in good condition - $180 plus shipping/paypal
_DSC0931 by bonspeed07, on Flickr-'96-'00 Civic CDM OEM airbag delete tray(Type K)with brackets - $60 SOLD!
_DSC1555 by bonspeed07, on Flickr- '97-'00 Acura 1.6 EL power mirror switch with heat function(black)with pigtail - $50
_DSC1560 by bonspeed07, on Flickr- '97-'00 Acura 1.6 EL gauge cluster(a/t) reads 164,096 km's not miles, lights up amber, direct bolt-on to any '96-'00 civic and first gen. CR-V, small bubbles showing by fuel and temp gauge area and RPM hence the price - $120 - SOLD!
_DSC1566 by bonspeed07, on Flickr- '96-'00 Civic gauge cluster(m/t) reads 272,989 km's not miles - $60
_DSC1568 by bonspeed07, on Flickr- '97-'00 Acura 1.6 EL side mirrors, power mirror manual folding with heat function(needs switch, harness and relay for heated mirrors to work) comes with inner cover, direct bolt-on to any '96-'00 Civic sedan - $180
_DSC1576 by bonspeed07, on Flickrall prices does not include shipping and paypal fees.
Contact:
pm replied!
http://www.flickr.com/photos/51799266@N02/7459232382/http://www.flickr.com/photos/51799266@N02/7459232382/ by http://www.flickr.com/people/51799266@N02/, on Flickr
update:
- Tilt plate holder - SOLD! 1 more available
bump!
bump!
update:
- '96-'98 Civic Si manual transmission ECU OBD2A(P2P) - SOLD!
- Spoon/Vision rear upper strut bar - SOLD!
price for middle one shipped to 11717 NY http://farm9.staticflickr.com/8178/8...d77d97d9_b.jpg
what's your zip code? so i can get you a shipping quote too. thanks!
