some one keyed my prelude.
Old Oct 17, 2002 | 01:26 PM
navybluelude's Avatar
Default some one keyed my lude.
Man the other day I just found out that my car just got keyed and im really p/o.
Im just wondering if you guys know of anything that i can use to remove the scraches and where can I buy it. There not that deep but they look really bad. tahks.
Old Oct 17, 2002 | 01:31 PM
LilImportKid's Avatar
Default Re: some one keyed my lude. (navybluelude)
BOO keyers!
my buddy's brand new Couger got keyed about 2 weeks ago in my high school parking lot. Not fun
Old Oct 17, 2002 | 02:04 PM
prelude1897's Avatar
You may beable to just buff it out...Used either wax, polish, or even both, and see if it'll come out
Old Oct 17, 2002 | 03:45 PM
PrecisionH23a's Avatar
depending on how deep the key mark is determines if you can get the scratch out. i would get some mother's or meguiar's clay barx... chances are it wont come out.
Old Oct 17, 2002 | 03:56 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: some one keyed my lude. (GudeH23a)
when oyu find the guy that did it, call me, and i'll come break his legs
Old Oct 17, 2002 | 04:18 PM
phildeez's Avatar
Default Re: some one keyed my lude. (Boosted97Lude)
if it is down to the metal only the body shop can fix. but if you run your fingernail across it and it barely catches then you can buff it out.
you can use 3m rubbing compound (fine cut). rub the scratch until you think it is the best it can get then finish it off with some polish and seal it up with wax. Remember don't rub too much you'll strip the paint. good luck
if you need anymore help
http://www.properautocare.com/byhand.html
Old Oct 17, 2002 | 04:26 PM
1-Bar's Avatar
Same thing happend to me a while back...big deep scratch from the middle of my passenger side door all the way to the tail light, that suxed ***. I found that those scratch removers work alright.....its just a clear coat that goes over. Its good for surface scratches. Only problem that it runs off w/ water.
lude2go
Dec 29, 2006 05:16 AM
atomicarmy
Apr 27, 2005 08:12 PM
Jeff99Base
Aug 2, 2003 09:07 PM
weakGOODJunKieS.com
Jun 9, 2003 03:44 PM
