15x6 +38 rims onto 04 Si
Old Oct 8, 2012 | 07:16 AM
TouringAccord's Avatar
H-T Order of Merit
Default 15x6 +38 rims onto 04 Si
I bought an 04 Si earlier this year, I have 15in Bridgestone Blizzak tires from my previous car and would like to use them on the Si now. I'm thinking 15in rims will be fine on the car but I just wanted to confirm before buying. I haven't had luck finding any locally, otherwise I would just test fit before buying.
Thoughts?
Old Oct 8, 2012 | 10:54 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: 15x6 +38 rims onto 04 Si
you might need to shave down some of the caliper... We put a 15 drag rim on an RSX and had to shave down some of the caliper to clear. On the EP3 I'm not sure. Might not have to.
Old Oct 8, 2012 | 12:50 PM
H-T Order of Merit
hmm, ok.
And are you referring to shaving down the OD of the caliper or the face of the caliper?
Old Oct 9, 2012 | 01:38 PM
poeticfinesse21's Avatar
02-03 EP3 came with 15's stock so as long as you still have the stock brake setup you will be fine. Only the Type-S won't clear it due to larger calipers.
Old Oct 9, 2012 | 04:43 PM
H-T Order of Merit
right, I was thinking the same thing. So I looked up the part numbers for the rotors and that but when the numbers didn't match I wasn't sure and wanted to double check before ordering the rims. Thanks
hmodel88
Honda Civic (2006 - 2015)
16
Sep 27, 2007 12:15 PM
leadphut
Jun 3, 2007 08:35 PM
WHTZ
Suspension & Brakes
Jan 11, 2006 05:17 PM
ramz7887
Jul 14, 2004 04:39 PM
