WV: 1997 Civic EX sedan - white on white, built/boosted D16
Contact info: PM me or post in this thread
I'm putting up my beloved car for sale. After transforming it from a 40+MPG daily to a decently clean, quick ride that gets around 30 MPG, I no longer have any time to enjoy it with grad school. Also, tuition isn't cheap and I'd rather sell my toys than take out huge loans.
NEW PRICE! $5,000 cash
I have several sets of OEM wheels (EM1, CRX Si swirlies) to replace the Kosei K1's. Open to partial trades + cash, or a newer stock car, but mainly just looking to sell.
1997 Civic EX sedan with ABS, sunroof, PS/PW, factory keyless, cruise control. The EX model came with 10.3" brakes in the front, as opposed to the 9.5" found on the DX and LX models.
Motor setup:
-D16Y8
-Bored to 75.5mm
-Slightly decked block
-Resurfaced head
-New OEM oil pump
-All new seals
-Chamfered and micropolished crank
-Stock cam
-ARP headstuds torqued to 70 ftlbs
-ACL Duraglide rod bearings, clearance 0.0015"
-Clevite 77 main bearings
-75.5mm Vitara pistons
-Rings gapped to .020" top, .023"middle, and .025" oil control IIRC
-FJ spec custom length I-beam rods. Compression ratio is close to 9.0:1
-OEM headgasket
-Vented valve cover with baffled catch can
Turbo setup:
-Garrett T3/T04e 50 trim .50ar compressor and .63ar exhaust housings with V-band flange on the hot side. Good for around 450whp. No shaftplay or smoke.
-Fast-turbo SS oil lines (-3an feed and proper BSPT->NPT fitting for the block)
-Tial 38mm wastegate
-560cc Evo injectors
-GM 3 bar map sensor
-Cast manifold
-FrontlineFab TIG'd downpipe with Vibrant mandrel bends and V-band flanges.
-3" mandrel bent exhaust with oval turbo muffler
-Walboro 255HP fuel pump
-Tuned on Neptune by John Kerr at J-KTuning, made 310whp/240ftlbs at 17-18psi. Revs to 7500rpm, anti-lag set at 5500rpm
-If you look through my build thread, you may see that I had a few problems with head lift, but taking out more timing has solved the issue. It does not push coolant under boost at all.
Drivetrain:
-EX transmission
-Pennzoil Syncromesh fluid
-Grinds 3rd if you jam it into gear
-Competition Stage 4 clutch - 6 puck sprung, disc was replaced approximately 1.5k miles ago.
-No ISB noise
I have a Gearspeed rebuilt EX transmission as well, can include with car depending on purchase price.
Interior:
-S2000 AP1 steering wheel, air bags and horn work
(have stock steering wheel as well)
-Black ball shift **** w/3" extension
-Mcdonald's checkerboard headliner
-No rips on seats
-No CEL's, all lights on cluster work
-All seatbelts intact
-Needs domelight cover and bulb
-MP3/aux-in CD player in the lower DIN
-Clarion rear 6x9 speakers
-I used a plug-n-play splice harness to power the stock headunit so the factory keyless entry works
-Glowshift wideband with Bosch 4.9 LSU sensor
-Prosport electronic peak and hold boost gauge
-All windows/sunroof, power locks work.
Exterior:
-Mini-Morimoto bixenon projector retrofit w/4500k bulbs and relay harness
-White LED license plate light
-AVS in-channel rain deflectors
-BYS/Airwalker replica front bumper (cracked and zip-tie'd on passenger side)
-Paintmatched mirrors and sideskirts
-Driverside fender needs to be replaced - the lower balljoint broke a few months ago and the tire deformed the fender. I have an OEM factory painted replacement depending on selling price.
-Some rust on both quarter panels. No holes but it's bubbling on both sides.
-Some door dings as to be expected on a 15 year old car.
-Original paint on body, never been repainted.
Suspension/wheels:
-Progress CS-II full coilovers with 350f/350r spring rates. Rides exceptionally well, not bouncy at all.
-ASR rear subframe brace
-GSR rear swaybar
-Kosei K1 16x7 +43mm
-Falken RT-615k tires with good tread. Very sticky tire.
-Gold Muteki extended lug nuts
-Driver side rear wheel bearing hums. It's under warranty from Advance Auto because I replaced it last year, but I no longer have the time to do this.
Maintenance:
New passenger front wheel bearing
New battery
New distributor cap/rotor
New spark plugs (NGK BKR-7E)
New driver side lower balljoint
New fuel filter
New driver and passenger axles
I have invested a lot more money into the car than my asking price...but that's how it always plays out. The car is pretty quick and will serve as a fun daily or a race car if one so desires. In fact, I took FTD at a local auto-x last year with this car, it handles like a dream.
On to the pics...
Slipstreams are gone, car is on Kosei K1's
Motor setup:
-D16Y8
-Bored to 75.5mm
-Resurfaced head
-New OEM oil pump
-All new seals
-Stock cam
-OEM headgasket
Turbo setup:
-Cast manifold
Drivetrain:
-EX transmission
-No ISB noise
Interior:
(have stock steering wheel as well)-Black ball shift **** w/3" extension
-No rips on seats
Exterior:
Suspension/wheels:
-GSR rear swaybar
Maintenance:
New battery
New fuel filter
On to the pics...
My entire build thread from beginning to end documenting everything I did to the car:
http://www.wvmotorsports.com/threads...Civic-EX-Sedan
I think my buddy and I passed you on the way home from the East Coast Honda Meet in VA. we were in a '02 white S2000 w/ mugen hardtop on teal colored Work VSXX wheels..anyways, from what I remember this car is clean. good luck with sale brotha!
Can you meet me halfway?
I'd love to check it out, Uniontown is about as far as I can go day to day, because I work a few jobs in the city or Pittsburgh.
I can meet in uniontown. However the car is getting a bigger intercooler/injectors right now, new bumper, and new paintjob. Might be a couple weeks before it's done. PM me if you're serious about meeting up
