crx wiring nightmare :(((
Just got a b20vtech swap into an 89 crx si... when i use the stick off the steering wheel to turn the headlights off, my ac lights and dash lights all stay on, meaning i can either leave the marker lights on, the headlights on, or the dash and ac lights on... Therefore draining my battery overnight... i found out that if i remove the blower motor fuse, then i dont have this problem, however, my stereo and interior overhead light wont work.... if im not mistaken the stereo shouldnt even be wired to this fuse... whoever did this really messed the wiring up.... any help? any good links to crx wiring and such?? im not even sure what to ask... im a bit overwhelmed.. thanks
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Sounds like either someone spliced something into the car the wrong way or a major short. Go thru the car anf make everything stock again and check all wiring. Sounds like a broken headlight switch too.
thanks alot man, whoever had the car before me ghetto rigged all of the wiring, theres lots of wires that go nowhere and such...im thinking ill need to overhaul it all.. any idea why someone would throw a toggle switch onto the blower motor ?thanks
Troubleshooting electrical problem when wiring is "ghetto rigged" can be impossible, you may be far better off, just replacing any/all damaged wiring harnesses.
Sounds like it's time for a trip to your local PicknPull. 94
