92 acura gsr startup beeping problems
I have a 92 acura integra gsr. Whenever I turn the key into the start position, even before starting the car, it'll beep 4 times like it normally does. But after that, it starts beeping faster and more constant. I was wondering if I could get a solution to this, thanks!
What do you mean "beeping"?
What is "beeping". do you mean the warning chimes?
If so the chime is controlled by the ICU, a common problem on older Honda/Acura, maybe not your particular problem, but all sorts of other problems.
Do your intermittent wipers work?
Does the rear window defog work?
Does the seat belt warning work?
Does the key still in ign. warning work?
Does the lights are still on warning work?
Does the dome light work off the drivers door?
Do the front side markers work properly? 94
HondaTom87
May 18, 2011 05:42 PM
