GSR trans help
"Hydro" as in hydraulic, refers to the method by which the clutch is engaged/disengaged. This is opposed to cable. Technically, either will bolt up to your engine but a cable trans will require a mod kit (not worth it). Ideally, look for a GSR tranny from a 94-01. Of course, the older the tranny, the more worn it will likely be. If you're in a pinch, any 94-01 Integra tranny will do but LS gearing is not ideal for a GSR.
CaptainBuster
Jun 19, 2014 02:18 PM
90lsvcrxva
Transmission & Drivetrain
Oct 10, 2008 09:07 PM
