Most DURABLE High Heat Paint
Old Oct 6, 2012 | 02:27 PM
Vagitarian's Avatar
Default Most DURABLE High Heat Paint
What is the most durable longest lasting aerosol paint that is readily available?
Im looking to paint a few things. The turbo being the one I think needs the most durable paint. I for sure want to paint the compressor housing, which I think regular 500 degree duplicolor engine enamel may be good enough for, aswell as my valve cover, intake manifold and transmission.
I was also hoping to paint the exhaust housing of the turbo, which obviously sees extreme heat, but I hate the look of a fresh looking motor and a rusty exhaust housing like they all go on our daily drivers.
Is there a paint that can take the abuse? And not squish/ruin when tightening fasteners into it??
I have several weeks to do this paint project so if a paint needs to hardnen for some time afterwards to become even more durable that isnt a problem.
What are you guys using?? Hopefully with a year+ durability. Pics of how things look JUST painted arent really relevant. I want durability and long lasting
Thanks for any tips
Old Oct 6, 2012 | 04:34 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Most DURABLE High Heat Paint
500 degree? You obviously are not at all familiar with how hot a turbo can get. You could get up to 2000 degrees depending on conditions. Probably nothing off the shelf is gonna cut it. Look into ceramics.
Old Oct 6, 2012 | 07:10 PM
Vagitarian's Avatar
500* for everything but the hot side housing.
Hot side housing is the only thing Im worried about it really just disintegrating, Id also like to know a durable paint that will be rock hard and not chip or discolor quickly.
I was thinking of even just high heat clearcoating the clean bare aluminum for the intake manifold, turbo cold side housing, valve cover but Id still need good strong clearcoat
Old Oct 7, 2012 | 10:50 AM
Vagitarian's Avatar
anyone
Old Oct 10, 2012 | 02:32 AM
Vagitarian's Avatar
hulk green 900 degree?? Duplicolor engine enamel series
Old Oct 10, 2012 | 02:44 AM
solis153's Avatar
Closet thing I could think of http://www.designengineering.com/cat...licone-coating
Old Oct 10, 2012 | 06:33 AM
kyden's Avatar
paint is never going to work on the turbine housing. you're gonna have to go with a coating, such as swain-tech or jet hot.
Old Oct 10, 2012 | 01:50 PM
Vagitarian's Avatar
couple guys on the grand national forums say they paint there housing with success
Old Oct 10, 2012 | 02:00 PM
jdmadam's Avatar
The best aerosol high heat paint that I have used is VHT FLameProof header paint. It is rated at 2000*F. You can buy it at any Pepboys. I've use it on headers, charge pipes, turbos, downpipes, and mufflers with no problems.
Old Oct 10, 2012 | 02:45 PM
Vagitarian's Avatar
Ya I have seen that brand actually but never read the can because they keep it locked up at my local store.
Only comes in silver and black right?
Im curious if it would REALLY work on turbo hotsides though
Old Oct 10, 2012 | 04:55 PM
jdmadam's Avatar
It actually comes in quite a few colors but black and grey is typically what you see in most stores. You have to order most other colors. Your store can probably order you other colors. Here is a link ----> http://www.vhtpaint.com/products/flameproof/
I have never painted the turbine housing of a turbo with this stuff but I think it might get the job done.
Old Oct 10, 2012 | 05:24 PM
Vagitarian's Avatar
^^^ the curing process they list on there site is quite extreme, heat cycles increasing all the way up to 650* degrees!!! **** I dont even know if my oven goes over 500 lol
I might give it a try
Old Oct 14, 2012 | 05:45 AM
Vagitarian's Avatar
Anyone think painting the turbo exhaust housing is possible?? Or the center section??
wdissident
Paint and Body
Jan 25, 2009 09:09 AM
92hatchattack
Paint and Body
Mar 10, 2008 05:06 PM
awalp
Nov 13, 2006 07:01 PM
its WANG yoO
Nov 20, 2002 03:40 PM
