Transmission & Drivetrain Gearboxes, Differentials, Clutches
Y21 B16a w/ clutch pack LSD...it clicked and clunked but it is ok? *PICS INSIDE
Old Oct 6, 2012 | 12:18 PM
beenba's Avatar
Default Y21 B16a w/ clutch pack LSD...it clicked and clunked but it is ok? *PICS INSIDE
Hi Everyone,
I drove this transmission on my B16 for approx two years. During the two years of driving it it always clicked and clunked when turning corners...
I thought for sure the differential was wore out and I swapped in another tranny with an open diff.
Now I am boosted and want to go back to LSD. So yesterday for fun I decided to tear the old transmission apart to see the LSD.
I have researched about 5 hours so far into clutch LSDs, and I haven't seen ANY pictures of what these differentials are supposed to look like new. Here it was mine looks like inside.
-10 bolt final drive gear 66T
Clutch packs:
Spider Gears and Ramp unit:
Everything seems to be in excellent shape to my surprise. I don't see any chatter or cracks or extreme wear..
Was I just using the wrong fluid??? I was using a 90w fluid with some lucas LSD additive back when I was driving with this transmission.
Would shimming the clutch packs 0.020" help during reassembly?? Maybe tighten things back up to account for any wear?
Thanks!
Edit: Is using a clutch type LSD good for high HP DD? I'm making around 450whp and would like to be able to go to the track w/ slicks about once a month.
Edit#2: I should mention that this transmission has been apart before. I could tell from the RTV sealant. So maybe this inst an OEM diff???
Old Oct 6, 2012 | 12:45 PM
beenba's Avatar
Default Re: Y21 B16a w/ clutch pack LSD...it clicked and clunked but it is ok? *PICS INSIDE
Wow...could this be a mugen LSD diff?? After some more research I found these pics on this forum. They look identical to what I have.
http://www.d-series.org/forums/trans...en-tranny.html
Should I be excited? I have no idea right now.
Old Oct 6, 2012 | 03:03 PM
bryse68's Avatar
noise during turns are normal with a clutch type lsd. just make sure you use the correct additive and break in the clutches properly.
Old Oct 6, 2012 | 11:07 PM
Mista Bone's Avatar
D Tranny Guru
1/3 tube of Tras X Posi-Lube does wonders for diff clutch chatter.
Amazon Amazon
In my Kaaz LSD I ran Penn. Synchromesh and the additive. Funny they were stocked next to each other at Autozone.
Old Oct 8, 2012 | 05:55 AM
beenba's Avatar
Thanks for the tips. Can anyone confirm this is a mugen unit?
That_DA_guy
Sep 27, 2015 07:19 PM
halfakneegrow
Apr 15, 2014 10:23 AM
Chiller
Feb 20, 2006 02:05 AM
xplhavoc
Feb 23, 2004 07:03 PM
puffinrice
Apr 1, 2002 08:48 AM
