1995 integra ls trans problems?helpp
Old Oct 5, 2012 | 07:23 PM
anthonymiller's Avatar
Default 1995 integra ls trans problems?helpp
i have a stock 1995 acura integra ls 5 speed and the trans will go into gear sometimes but other times it will lock me out of all gears . i checked the slave cylinder and thats fine and the master cylinder and secondary cylinder are full of fluid . any ideas of what be the problem ?
Old Oct 5, 2012 | 07:44 PM
redrocket_ej1's Avatar
Default Re: 1995 integra ls trans problems?helpp
Have you tried to bleed the clutch? Any leaks? Have you checked your transmission fluid level?
Old Oct 5, 2012 | 07:47 PM
i will try to bleed the clutch and trans fluid level is okay its just wierd because i will be okay for a while then it wont just go into gear
Old Oct 6, 2012 | 06:55 AM
fcm's Avatar
fcm
Old Fart
What redrocket_ej1 said, bleed the clutch hydro system.
I would go one step farther and replace the fluid completely, just like brake fluid, it gets old and needs to be replaced, use DOT3 or DOT4 brake fluid.
Also, get under the car, [hoist or jack AND jack stands] and inspect the shift linkage, pay close attention to the Change Extension rod, #14...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal and it's connection to the transmission, #s 15, 16, 17 and 30.
The Change Extension rod compensates for engine torque, if it is loose, worn out, bent shifting can be a problem when accelerating and/or decelerating.
If you have excessive engine torque, check your engine mounts...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
Old Oct 6, 2012 | 08:06 AM
thanks guys!
.hawaii
Nov 2, 2009 07:08 PM
maxogsr
Oct 4, 2009 01:51 PM
funtak
Nov 9, 2007 04:48 AM
epoch707
Feb 21, 2006 06:13 PM
carlosd68
May 14, 2005 10:14 PM
