99 honda accord acceleration problem
Old Oct 4, 2012 | 01:39 PM
ransonea's Avatar
Icon2 99 honda accord acceleration problem
i have a 99 v6 honda accord. when accelerating at low speeds it bogs down and then surges after a few seconds. it doesnt do this at high speeds only low. over the past couple years i have done the following: replaced EGR, cleaned EGR paths, replaced spark plugs and wires, new ignition switch, new main relay, new distributor cap, cleaned throttle body, new fuel pump and filter. not sure where to start now
Old Oct 4, 2012 | 02:40 PM
shipo's Avatar
Default Re: 99 honda accord acceleration problem
It sounds like you're throwing parts at the problem, a practice which can often cause more issue than it solves. Have you had the codes read? If so, where do they point?
Old Oct 6, 2012 | 05:43 AM
Lost Again's Avatar
Stop by a parts store and have them scan for codes.
Old Oct 12, 2012 | 12:44 PM
cavy95's Avatar
I have a 2000 accord v6, and have been having the same problem for a year know. I have changed the spark plugs, seafoamed the intake, and cleaned the throttle. I understand is may a need for a new PCM and fuel pressure regulator. Any TSB on this? We are not the only ones.
Old Oct 12, 2012 | 12:47 PM
shipo's Avatar
What has led you to this conclusion?
Old Oct 12, 2012 | 03:48 PM
cavy95's Avatar
Thats the information I get from this website:
http://mechanics.stackexchange.com/q...-what-may-caus
also found this:
http://www.motobild.com/honda/2000-h...-with-pcm.html
and this:
http://www.6thgenaccord.com/forums/s...d.php?p=679044
Old Oct 12, 2012 | 05:27 PM
shipo's Avatar
The symptoms you related earlier don't really match up with the descriptions of S/B 00-024; do you have an early VIN lower than the specified VINs in the second link?
Old Oct 12, 2012 | 06:07 PM
cavy95's Avatar
I do. Why are you suggesting I'm barking up the wrong tree? What are your thoughts? Did I mention my SRS light has been on for 4 years and I have reset it and the dealership has as well multiple times. My problem may also be the PCM.
Old Oct 12, 2012 | 10:57 PM
holmesnmanny's Avatar
The first thing to do is to get your car scanned for codes. If nothing shows up, first thing you could do is replace the oxygen sensor if you have never replaced it before.
Old Oct 13, 2012 | 04:41 AM
shipo's Avatar
Unless I read it wrong, the main thrust of SB 00-024 was to correct a warm restart/heat soak issue where the engine ran perfectly following a cold start and perfectly well once the engine had been running for a few minutes following a heat soak restart. I don't recall you mentioning these symptoms.
Old Oct 13, 2012 | 08:50 AM
cavy95's Avatar
You are correct. I was just trying to post some options. The first website suggests the fpr and computer and the other they have the heat soak problem. Just trying to help, but I see your point of view. My offerings aren't conclusive but offer a solution to another problem. What are your suggestions to this situation? I did replace my upstream and down stream sensors last winter.
Old Oct 13, 2012 | 09:19 AM
shipo's Avatar
I'm thinking we're to the point where it will be very difficult to diagnose this issue over the internet; might be time to consider a professional technicial.
hondaguy4642
Jun 5, 2018 01:35 AM
KRCXIV
Jun 23, 2015 09:51 AM
pgilger
Mar 26, 2012 07:15 AM
