CRX D16Z5, idle and rev problem ....wiring?
Hello guys i have one problem with my crx that is rly rly anoying.... ok let's go..
- i bought Crx with blown head gasket and no radiator.... ok no problem i said....
brought it home dismantled the head, got a new gasket, polished the head on machine, the head is in perfect condition. Cylinder, pistons, everything great like new (i was told that the engine was rebuilt 15000km ago, so from what i see it is).....
the problem is next, i start the car he goes up to bout 1300rpm (cold), but working on 3 cylinders, cylinder number 4 doesn't work (the one closest to dizzy)...
it is getting fuel and spark but wont fire.... ERROR CODE 4(CKP?) crank positioning sensor?
i replaced a dizzy from my civic D16A9(are the same) still no succes.... i took that other sensor from exhaust camshaft... again the same ****....
1 p.s. the engine should be the one with lambda and cat but it doesnt have them, and the ecu is for A9 in which he is the same except lambda and CAT so i dont think that is the problem....
i rly need ur help, from where to start looking for problem?
btw i tryed ecu from my civic because they are the same, still nothing....
AND IT WONT REV PAST 3K rpm , for most of the time, sometimes i manage to get to rev limiter, BUT RARE...
DRAGON JOEY
Feb 28, 2011 06:27 AM
hondawhat?
25
Nov 30, 2010 11:01 AM
DustinPennington
Apr 22, 2008 02:44 PM
spidy005
21
Feb 9, 2007 08:36 AM
