Fuel Pump Switch Issues 89 EF Sedan. HELP
Old Oct 4, 2012 | 10:08 AM
Effingcrump's Avatar
Default Fuel Pump Switch Issues 89 EF Sedan. HELP
Hey guys, I got my swap running right, drove it around and it ran immaculately, although, it had a switch running to the fuel pump.
The switch was located right behind the emergency brake, I had everything out in the open and when I started it this morning I guess the wire touched the bare metal of the car and I heard a spark.
Well now the car won't start.
I tried putting the two wires together and starting it as well as unplugging and plugging back in the plug that runs to the fuel pump, and both resulted in the car not starting.
Anyone have an idea as to what it could be, and what I could try before replacing the fuel pump.
Old Oct 4, 2012 | 12:32 PM
Default Re: Fuel Pump Switch Issues 89 EF Sedan. HELP
117 views and nothing?
Old Oct 4, 2012 | 12:38 PM
sleepingciv's Avatar
check fuse #14 under the dash also check the big fuses under the hood
Old Oct 4, 2012 | 12:42 PM
Alright will do, I get off work in like ten minutes so ill check it out when I get home.
NovaRex
Jan 27, 2016 06:59 AM
jianwa
Jul 31, 2010 02:03 PM
4drint3gr4
43
Sep 10, 2009 02:07 PM
00trdtaco
Aug 20, 2009 06:42 AM
LSpimpTEC
Jul 14, 2003 07:37 PM
