EF's with B16's and Ground Control Coilovers...
Old Oct 17, 2002 | 11:41 AM
SqueezinEF's Avatar
Default EF's with B16's and Ground Control Coilovers...
With this setup do you problem of bottoming out? Also, what spring rate do you have? I have GC's for the Civic. I believe that the front are 600 but I have idea what the back are? Any ideas. I am also thinking that my struts are bad but I want to know if I should change the GC's out also or just get new springs for them. HELP please.
Old Oct 17, 2002 | 12:06 PM
Home Skillet's Avatar
Default Re: EF's with B16's and Ground Control Coilovers... (SqueezinEF)
i don't bottom out but my headers get dented once in a while. I have dc 4:1's. GC's are fine not the best though.
Old Oct 17, 2002 | 12:10 PM
Shea-bird's Avatar
New User
Default Re: EF's with B16's and Ground Control Coilovers... (Home Skillet)
well 600lb spring rates are ridiculous for a street car...
I would get your car looked at to see if you need new struts.
Old Oct 17, 2002 | 12:12 PM
SiR Kid's Avatar
New User
Default Re: EF's with B16's and Ground Control Coilovers... (Shea-bird)
I've got 350 front/250 rear which is the standard EF kit.
It rides well, but a little bouncy cause my front shocks are FUBAR.
I've got the car with about .5" wheel gap in the front, and 1.5" in the back because of bad alignment.
Old Oct 17, 2002 | 04:39 PM
performula's Avatar
Default Re: EF's with B16's and Ground Control Coilovers... (SiR Kid)
You will need stiffer shocks to keep from bottoming out.
Old Oct 17, 2002 | 04:41 PM
performula's Avatar
Default Re: EF's with B16's and Ground Control Coilovers... (performula)
Unless you have an 80lbs. spring weight. Max. spring rate I would rec'd for street are 400-500lbs. <- pushing it with the 5OO.
[Modified by performula, 1:43 AM 10/18/2002]
Old Oct 17, 2002 | 04:48 PM
red civic standard's Avatar
i have ef with b16 and GC with 450f and 350r on Koni Yellow shocks and my ride never bottoms out...i am riding right at the top of the GC. My perches got stuck though...i hate GC's perches.
Old Oct 18, 2002 | 05:44 AM
SqueezinEF's Avatar
Default Re: EF's with B16's and Ground Control Coilovers... (red civic standard)
Thanks for the replies. I am going to get new struts. It's what I suspected but I just wanted to verify. How much would I expect to pay for Koni Yellows? I am kind of tight on funds so but I want struts that I don't have to worry about.
H-T
Old Oct 18, 2002 | 08:17 AM
performula's Avatar
I paid $476.
Old Oct 19, 2002 | 08:06 AM
SqueezinEF's Avatar
Can anybody tell me what these numbers mean, these were on my springs of my Gc's.
Rear: Ground Controls 29/97 GC 180.64.44
Front: Eibach 29/96 ERS 0700.250.0325
Old Oct 19, 2002 | 08:22 AM
blacksoul's Avatar
Dont you guys have ED's?
Old Oct 19, 2002 | 10:03 AM
johnzm's Avatar
Default Re: EF's with B16's and Ground Control Coilovers... (blacksoul)
des it really matter? EF/ED whatever
Old Oct 19, 2002 | 08:50 PM
SqueezinEF's Avatar
Default Re: EF's with B16's and Ground Control Coilovers... (johnzm)
ttt
Old Oct 19, 2002 | 08:54 PM
johnzm's Avatar
hows the ride with yellows? im very interested in the setup. and how low can u get it?
Old Oct 20, 2002 | 07:49 AM
Blown90hatcH's Avatar
If I am not mistake, those are 250 front and 180 rear. I am almost pos on that. Those fronts are too soft for a B16a.
Old Oct 20, 2002 | 08:15 AM
performula's Avatar
You mean, the lowest they'll handle?
They can take whatever AS LONG as they do not bottom out, covered under warranty too.
Old Oct 20, 2002 | 09:50 AM
performula's Avatar
Are the Koni and Bilstein adaptors the same?
Old Oct 20, 2002 | 09:55 AM
91CivicSi's Avatar
I have a pretty similiar setup..91 HB, GSR motor, and Skunk2 coilovers. The spring rates are 400f/300r. It's a little bouncy but not unbearable. The car seldom bottoms out but the suspension will over BIG bumps or dips, buuut the tops of my tires are tucked at all 4 corners.
Old Oct 20, 2002 | 05:49 PM
SqueezinEF's Avatar
Come on guys. I know someone can help me out. Can someone tell me what these numbers mean exactly.
Old Oct 20, 2002 | 05:59 PM
Rob!'s Avatar
i have a 91 hf and im in the middle of putting a b16 in...im running neuspeed race springs...is this motor going to lower my car more? if so approx. how much?
Old Oct 20, 2002 | 10:49 PM
I am almost positive that they are 250 front and 180 rear....but why dont you call Eibach/Ground control and stop wasting time.
Old Oct 22, 2002 | 07:52 PM
ZC_powered_4dr.'s Avatar
if ur on a budget for the struts ive got KYB AGX's they are great with the GC's i paid 400 for all 4 of mine out of summit. but if got the extra cash by all means go with the koni yellows have heard many good things
type-ONE
Suspension & Brakes
31
Aug 28, 2009 11:01 AM
CivicSi95
Suspension & Brakes
Jun 29, 2009 11:12 PM
crxsiperf
Sep 9, 2007 09:33 PM
f1 vtec
Suspension & Brakes
Jan 30, 2005 09:15 AM
BrandonClaps
Nov 7, 2003 10:36 PM
