Tire wear and new struts... See pix need help
Old Oct 3, 2012 | 03:51 PM
prinler's Avatar
Icon2 Tire wear and new struts... See pix need help
I need some help. I have nice set of Dunlap Z rated tires on the rear of my 02 Accord coupe. The outsides of my tires are worn down to the belt in under 8000 miles.
I recently replaced the struts with a budget brand from eBay. Had them installed by a friend from work who works out of his shop at home. I had a recent front end alignment and they found a bent arm or something in the rear. The arm was repaired and re installed.
Since the strut install there is a strange wiggle in the rear when i hit a bump. like the azz end shifts to the right, like a fish tail. I have had my car up on the rack and do not see anything visually alarming.
symptoms: Tail wagging on bumps while on freeway
Tires are wearing on the outside and quickly
Some hunting i found a nice site here explaining that its camber but my car doesn't have adjustable links...
Old Oct 3, 2012 | 03:56 PM
djkurious's Avatar
Default Re: Tire wear and new struts... See pix need help
Outside tire wear= positive camber.
Old Oct 3, 2012 | 06:12 PM
eirigance's Avatar
If it were the Struts it would be chopping the Tires not balding the outside so probably not those. It's gotta be the Camber.
Posted from Honda-tech.com App for Android
Old Oct 3, 2012 | 06:33 PM
cstone's Avatar
struts that are too long would cause positive camber. positive camber is your problem like others stated. your struts are probably the reason for the positive camber.
Old Oct 3, 2012 | 07:28 PM
prinler's Avatar
Ok, positive camber is my call to but what would cause the rear end to move around and what would cause the tire to wear down? I have been racking my brain and picking every garage mechanic i know or even dont know! I hope you pro's can help me narrow it down so i can replace the that part and bring it back to original.
One Honda guy suggested i just buy adjustable rear end links and be done with it....
Old Oct 4, 2012 | 12:12 AM
cstone's Avatar
Camber causes the wear due to a smaller patch of your tires taking the weight. The other problem sounds like body roll. This can be caused by weak struts. You said that it shift to the right which probably means the stout on that side is weaker. That's the risk of buying EBay bargain brands.
Old Oct 4, 2012 | 05:27 AM
Mayhem_J30's Avatar
Is the toe adjustable in the rear on this model? Sounds like some possible bad toe out on one side in the rear.
Old Oct 5, 2012 | 04:06 AM
MAD_MIKE's Avatar
MM Gruppe B
Those tires look worn. Can you take a picture of the whole tread? Hard to see what the inside blocking looks like.
Old Oct 5, 2012 | 07:57 AM
v4lu3s's Avatar
RTFM
why would you do a front wheel alignment only? do a 4 wheels and get the measurements on the rear so you can actually have a clue what all is wrong. you do have problems though, chances are its more than one bent part...
3easy21
Jan 27, 2013 09:04 PM
H8BOOST
Honda S2000
Apr 12, 2010 06:38 AM
GSRkrod
Honda S2000
17
Oct 13, 2009 05:15 PM
djmeowmix Yes A Girl DJ
28
Jan 11, 2007 09:24 AM
cstoltie
Aug 24, 2002 11:09 PM
