Rear heat shield (behind manifold) on 93 Civic DX?
Old Oct 3, 2012 | 02:54 PM
fragmare's Avatar
Default Rear heat shield (behind manifold) on 93 Civic DX?
I was browsing through my service manual the other day looking for torque specs, and I happened to come across a diagram showing a REAR heat shield located behind the exhaust manifold. My car definitely did NOT come with this when I bought it, but then again I bought it used. Was this only included on some trim levels, or is this something I should have on my car?
Old Oct 3, 2012 | 03:06 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Rear heat shield (behind manifold) on 93 Civic DX?
My B16 has one and I think the B8 before it did too, not sure about my Y7.
Those manifolds come kinda close to the block, not a bad idea to have it and it might not be a bad idea to not have it. Most aftermarket headers don't have them, but are also usually spaced away a little.
I wouldn't loose sleep over this
Old Oct 3, 2012 | 03:09 PM
kaiba's Avatar
Don't worry about it.
Old Oct 3, 2012 | 04:00 PM
fragmare's Avatar
I've driven the car for 3 years without it with no negative impacts. I'm not sweating it.
The main reason I ask is that I'm in the process of restoring the car, so if it was supposed to have one, then I'll head down to the junkyard and see if i can find one in good shape. I just got done repainting the front heat shield, and I've got some primer/paint left over... seems like a perfect use for it, to me. :D
dadsvtechonda
May 3, 2007 05:35 PM
iNetForce
Mar 5, 2006 09:44 AM
civicmatt
May 18, 2003 09:19 AM
PatrickGSR94
Apr 7, 2002 05:50 PM
