electrical issue no brake lights/horn (90 accord) plz help!
Old Oct 3, 2012 | 11:29 AM
hatchinprogress's Avatar
Default electrical issue no brake lights/horn (90 accord) plz help!
Ok 1st of all I'm doin this from my phone since I have no internet...which means its been hard to do a real search (but I have been doin as much readin as I can)
1990 accord ex about 210,xxx miles automatic
Was informed that brakes lights stopped working (while drivin down the street)
All 5 lights(rear window) didn't work when I hit brake pedal....but tail lights,hazards,blinkers work an all lights worked when arming (viper) car alarm.... so brake lights(bulbs work an wiring seems good)...except 4braking
Brake switch works and dosent stic.
Horn fuse under keeps blowing(20amp) and brake lights,horn,cruise cont. All stopped working (I put a 30a fuse in horn slot(I kno its bad) ) now some brake lights work @ times.
Also for a while the shift lock stuc...an had to use key to shift.....well now since the light issue....I don't need a key for the shift lock?
Please help w/any info....I can't afford to get this car impounded(or tix) but I can't work w/out car.
Old Oct 3, 2012 | 11:51 AM
cstone's Avatar
First off, pull out that 30 amp fuse! If you start a fire your brake lights and horn will be the last of your worries. Once you've done that start tracing the wires from the tail lights. I believe they run down the driver's side. You probably have cracked insulation on one of the positive wires.
Posted from Honda-tech.com App for Android
Old Oct 3, 2012 | 12:44 PM
Default Re: electrical issue no brake lights/horn (90 accord) plz help!
Thank you! Just pulled the 30a...still been reading so tryin to troubleshoot best I can....both horns are unplugged and I put a 20a fuse bac n the horn slot.....I hit the horn(no sound ofcourse) but the fuse dosnt blow! So could it be just bad horns? (Those I can go w/out)
Thanks for any feed bac
Old Oct 3, 2012 | 01:53 PM
cstone's Avatar
Are the brake lights working now that the horn buttons are disconnected? If so the problem is probably horn related.
Old Oct 3, 2012 | 02:48 PM
Ok so fuse still works an I tested to see if brake lights now function.
If your standing behind the car...imagine the lights are numbered 1-2-3-4 (#5 is in rear window)
Well lights #1 and #3 work (#2-#4- an #5 still do not work)
Does that help narrow anything down? I really appreciate your help btw
Old Oct 3, 2012 | 05:13 PM
cstone's Avatar
That would lead me back to the wiring (assuming you have checked the bulbs and sockets). get a multi meter or at least a test light and check for power. I prefer to start at the source when checking wiring but since its a PITA to get to brake light wiring I would start at the socket and work towards the front.
Since the fuse is no longer blowing it could possibly be bad grounds causing those lights not to work. You may want to find a wiring diagram for your car. Google has them.
Old Oct 4, 2012 | 11:36 AM
I can't find an accord wiring diagram anywhere (tried google) how close are the wires for civic? I do have a chiltons 84-95 civic book
Old Oct 4, 2012 | 01:25 PM
cstone's Avatar
Check your PM.
The Horn diagram can be found on page 1848.
I'm having a hard time locating the Brake Light wiring diagram.
Old Oct 4, 2012 | 06:23 PM
Check your PM.
Appreciate all your help!!! Pm sent to ya (brake failure sensor ...maybe?)
Old Oct 6, 2012 | 07:01 AM
Lost Again's Avatar
Not following your "numbers" for the lights.
Replace the bulbs that are not working with new ones.
dsurette
Honda CR-V & Element
Aug 29, 2017 03:34 PM
tabartis
Dec 21, 2011 09:52 AM
gonzojoey
Mar 17, 2006 01:29 PM
camelspit
Feb 14, 2006 08:35 PM
classic69
Dec 22, 2005 09:09 PM
