Shifter Problemo!
Hey HT, Im in a little bit of confusion. My 94 si's shifter was super loose, so i replaced my shift bushings hoping it would stop the side to side movement. Unfortunatly it didnt
so now im here with my question. I did a search but couldnt find help. Ill attach some pics because i have a question about the link cabled (labeled as 13) in the picture below. It has a huge **** on the end facing the trunk. Then also (pictured) below theres a peice of metal with 2 wholes on it, so im kinda thinking there might be something missing which makes my shifter mover side to side while im in gear. If anyone has any help id appreciate it alot.
Thanks
so now im here with my question. I did a search but couldnt find help. Ill attach some pics because i have a question about the link cabled (labeled as 13) in the picture below. It has a huge **** on the end facing the trunk. Then also (pictured) below theres a peice of metal with 2 wholes on it, so im kinda thinking there might be something missing which makes my shifter mover side to side while im in gear. If anyone has any help id appreciate it alot. Thanks
nope, there's nothing missing. Did you replace the bushings at the transmission as well? I would also recommend tightening the bolt that connects to your shifter, and use loctite. Mine ended up rattling loose while I was on the highway, and I could only use 3rd gear
(it looks fine, what should i be looking for?
I bet its the Joint on rod 13, Take the whole thing off and see if its snug.. If it swings around loose its at fault! Should be alittle tightness at the joint and its super easy to rebuild and will feel tight agian.
confused on what your trying to say, if your talking about the part connecting to the trans its not possible to rebuild
david420
45
Apr 3, 2012 07:43 AM
