EJ6 Hatch LS/VTEC-T. - reeeallyy slow Build
Old Oct 2, 2012 | 10:14 AM
dicxonjim's Avatar
Default EJ6 Hatch LS/VTEC-T. - reeeallyy slow Build
Hello guys , not much of a talker here in H-T. But always on the site.
Anyways, I bought my 96 Hatch back in 2008, completely stock, then with a JDM B18C (GSR). Boosted, made 307whp, @8psi. With a .57 trim ebay turbo, and of course , got stolen after a year.
Anyways, I'm back with the same plattform, but different heart,
Here's the specs so far:
*B18B1 Block - new oil pump, ACL bearings, balanced & micropolished crank,wiseco pistons 10.5:1 , Connecting rods, arp con.rod bolts, ARP headstuds,cometic headgasket, new oem water pump, new OeM P72 timing belt
*B16A2 Head: 3 angle valve job, supertech spring & retainers, port and polished, B16A2 Cams and gears, Skunk 2 IM , Hondata IM Gasket, ID 1000's Inj , etc !,
*Turbo Syst. : Precision 6262 Journal, Turboxs WG, BRM Ram Horn Manifold, 2.25 IC Piping, 32x12x3 FMIC ,
I probably missed a couple of things , but that's so far what I have,
My goals is to hit the 4xx's on Pump Gas . Hopefully.
Pics will be up later.
I appreciate any help or input in advance .
Old Oct 3, 2012 | 04:25 AM
dicxonjim's Avatar
Default Re: EJ6 Hatch LS/VTEC-T. - reeeallyy slow Build
Here's a pic of the progress.
Also got a question, what spark plugs u guys recomend for this set-up ?
Thanks.
Old Oct 3, 2012 | 04:27 AM
dicxonjim's Avatar
Old Nov 12, 2012 | 09:10 PM
dicxonjim's Avatar
Took some parts off for Sand blasting and Paint .
Before:
Sand blasted:
Final Results:
Closer look.
Had to change of the Caliper Pistons, so went to the junk yard and got one for $3 bucks!!
Old Nov 12, 2012 | 09:35 PM
famous323's Avatar
you couldn't get a better caliper piston? looks like the corrosion ate through the chrome.
Old Nov 13, 2012 | 06:15 AM
dicxonjim's Avatar
Yes I did, picture shown is just the damaged pistOn. Didn't take one of the replacement , but its got no corrosion.
Old Nov 13, 2012 | 01:23 PM
jpm0830's Avatar
Like the custom gloves man
Old Nov 13, 2012 | 04:44 PM
dicxonjim's Avatar
Thanks, really expensive gloves there ! !
wist00s2k
Feb 28, 2015 10:04 AM
Shane_00integra
Sep 19, 2012 01:44 PM
bks84
Aug 21, 2007 10:12 AM
pdiggitydogg
Feb 8, 2007 06:57 AM
b20vtechatch
Mar 18, 2006 06:01 AM
