With these numbers, what times should I be getting?
Old Oct 17, 2002 | 10:40 AM
Norcalstoppy's Avatar
Default With these numbers, what times should I be getting?
This is in a 2nd gen Integra GS w/ PS, AC. The car weighs in at 2560lbs according to Honda w/o PS, AC, and ABS. So I'm guessing it weighs about ~2700 w/ everything. I'm running generic brand tires w/ about 50% tread at 20psi. I have to double clutch into third, or it just grinds for about 10 secs.....
Each of these are my best times, from different races at Infineon Raceway:
R/T - .508
60ft - 2.313
1/4 mile - 15.80
MPH - 88.53
Here's my dyno:
Thanks for your help.
Jay Kim
Old Oct 17, 2002 | 11:03 AM
raene's Avatar
Default Re: With these numbers, what times should I be getting? (AllMotorMonster)
Your MPH shows low 15 potential. My brother's old CRX timeslip was 15.2 @ 89 or something like that...
Old Oct 18, 2002 | 05:22 PM
gsrvx's Avatar
New User
9s
Old Oct 18, 2002 | 05:56 PM
Default Re: With these numbers, what times should I be getting? (RK)
9s
Go away. You big bully! Just because you're hairy as a monkey with a white hybrid hatchback doesn't mean you could be mean. Heh
Anyways.....no body?
And biatch! Jerry said, "Who the **** said that?"
Jay Kim
[Modified by AllMotorMonster, 6:56 PM 10/18/2002]
Old Oct 18, 2002 | 06:59 PM
gsrvx's Avatar
New User
Jay....people say this is pretty accurate:
http://www.prestage.com/carmath/calc_etmph.asp
Old Oct 18, 2002 | 11:25 PM
flip1199's Avatar
that seems about right i usually trap at around 88-89 with a 2.3 60ft and i get 15.6-7
Old Oct 26, 2002 | 04:07 PM
Default *update*
I went to Palmdale last night and my best times are as follows:
.520 R/T
2.430 60ft
15.994 1/4 ET
87.4mph
This time I finally figured out how to shift into 3rd without grinding. Before I used to get 16.2 with double clutching, but with new know-how, this is my best time. I consistantly got 16.04-.06. Hopefully with my new AN-R header and removal of PS and A/C, I could get mid 15s at Palmdale.
Jay Kim
Old Oct 27, 2002 | 09:15 AM
teg92's Avatar
Default Re: *update* (AllMotorMonster)
151whp and only 15.9? Something is wrong!
btw what motor is that? Power curve looks like a B18A, but between 5&6 it looks like something is going on.
Old Oct 27, 2002 | 09:53 AM
Default Re: *update* (teg92)
I agree. What kind of tires did or do you have when you got that 2.2 60ft? I have "General" brand tires.....that's the company name. That, I'm sure, is hurting my 60ft.
How much power is your car making?
Jay Kim
Old Oct 28, 2002 | 01:59 AM
AussieK24's Avatar
Yeah, I was about to say his VTEC was engaging too late but he aint got none
Old Oct 28, 2002 | 06:08 AM
CHEETAH's Avatar
trap is good enuff for low 15's liek a 15.1 or 15.2
try to cut it down to a 2.2 60' and it should work well. and shift a lil faster too ...
greg
Old Oct 28, 2002 | 08:39 AM
Default Re: *update* (b16a4me)
I have VTEC and voila! It's so subtle that you can't even see. The vtec engages at 4400.
Well, yeah. I have that problem too. My tranny grinds really bad in 3rd, so I have wait for the RPM to drop a little before I shift into 3rd.
Jay Kim
Old Oct 28, 2002 | 08:42 AM
gsrvx's Avatar
New User
Default Re: With these numbers, what times should I be getting? (CHEETAH)
Palmdale's elevation is not the greatest.
15.99 * .9679 = 15.47
87.4mph * 1.0337 = 90.35mph
Those would be his times at sea level.
Get those 60 footers down and toss the grinding LS tranny for a closer geared si tranny. I'm sure low 15s are within reach.
He has VT3C.
-Rod
[Modified by RK, 9:43 AM 10/28/2002]
shortlid
Honda Civic (2006 - 2015)
Jul 3, 2018 05:41 AM
Treyschls
Jul 25, 2017 03:18 PM
Andrei71
Sep 3, 2010 01:21 PM
silver97prelude
Mar 31, 2005 12:31 PM
