92' Accord Transmission Issue?
92' Accord Automatic
It appears to be stuck in one gear. The light indicator for drive is always lit up.. but it will go into park and reverse but even still the drive indicator is still lit up green. When I pull out and go up the road it will not change at all it's just stuck in drive at all times.. slight roar and it will not go above 30 or so mph.
Transmission fluid is fine..
I know this may not be a great deal of information, any ideas?
Find the two wire blue connector, I cannot recall at the moment if on the CB the connector is behind the glove box or the kick panel on the P.side.
Jump it, turn the car to ON(not start) and count the blinking light for the code.
Click on the H4A Troubleshooting link in my sig to help diagnose.
Might be the shift solenoid went bad. Located on front of trans. there is a lock solenoid and shift solenoid. Quick test: unplug and jump power to each terminal, should click. If weak click or none at all, replace.
gotdurt
Dec 18, 2006 04:48 PM
