92 integra with thick white smoke:(
Old Oct 1, 2012 | 06:17 PM
KtHaNxBai's Avatar
Default 92 integra with thick white smoke:(
its been sitting off for about 2 months, i just turned on and it is thick, does that mean bad rings?? what else can it be??? this sucks...what would the cost of fixing something like that be??? guesstimating..
Old Oct 1, 2012 | 06:20 PM
Fliptard's Avatar
Default Re: 92 integra with thick white smoke:(
White smoke? Burning coolant, bad headgasket. Get an OEM headgasket kit and pull the head. I use Felpro as well, and also a place called J. I. S. for my gaskets, haven't had an issues with them yet.
Old Oct 1, 2012 | 06:41 PM
KtHaNxBai's Avatar
is there any other way to tell if the headgasket is bad???? as far as visual?
Old Oct 1, 2012 | 06:43 PM
Fliptard's Avatar
Leak down test. compression check
Old Oct 2, 2012 | 02:35 PM
DeCePtEgRa's Avatar
Drop some oil from crankcase onto a hot surface, if it bubbles coolant is mixed in oil.
Old Oct 2, 2012 | 02:51 PM
KtHaNxBai's Avatar
ok, i did a compression test, they came up
210,210,190,200....as i pulled the sparkplugs, they were drenched in oil...could that be the rubbergaskets on the valve cover??? and can tht oil be seeping into the spark, thus causing the smoke???HELP!!!!
Old Oct 2, 2012 | 02:52 PM
KtHaNxBai's Avatar
oh, all the tests were basked on a 6 dry crank test. meaning 6 crancks then i got the number
Old Oct 2, 2012 | 03:01 PM
DeCePtEgRa's Avatar
As long as the engine was at op temp, and all the plugs were out when each cyl was tested. Burning oil will be a blue smoke, black is fuel, white is coolant.
Old Oct 2, 2012 | 03:20 PM
KtHaNxBai's Avatar
engine was cold when i tested it.
Old Oct 2, 2012 | 03:21 PM
KtHaNxBai's Avatar
all the compression test that i read was cold engine. never read that the engine needed tobe hot? yes all plugs where out.
Old Oct 2, 2012 | 03:27 PM
mouab18c1's Avatar
Motor needs to be at normal operating temps while doing a compression test with fuel supply disconnected and keeping it at WOT while cranking.
Old Oct 2, 2012 | 04:23 PM
Fliptard's Avatar
yes, let the car warm up, pull Injector fuse under hood, do each test again.
You could also do a pressure test on your coolant system pull all the plugs out and see if you hear air excaping into the cylinders
Old Oct 2, 2012 | 05:00 PM
iRockTheDA9's Avatar
210psi per cylinder(especially at cold crank) is quite high for an LS, unless its a vtec engine. There is probably coolant sitting in the cylinders from a bad headgasket which is causing the high compression readings.
my jdm b18b or LS, is fresh only 2500 miles and it had 175psi across the board at running temp, compression test(dry).
Old Oct 2, 2012 | 08:52 PM
DeCePtEgRa's Avatar
Disable ignition by unplugging distributor not sure if there is injector fuse but I could be wrong too
Old Oct 2, 2012 | 08:58 PM
standy xsi's Avatar
first off i would take it for a drive, bowt 5 to 15 min's should do. if its still smokeing when you get back do leakdown and compression... most of the time my car will smoke if i havnt started it for awhile. by the time i get to town its gone
Old Oct 2, 2012 | 09:33 PM
dickdragon's Avatar
I had the same problem, same questions,.... The fix... A new head gasket! I couldn't figure out why, if the gasket was bad cuz the plugs were drenched in oil and not coolant. The plugs were very oily, but if I payed closer attention to the thickness of the mysterious fluid on my plugs, I could see that it's was very watery like. Not just only oil!
Old Oct 3, 2012 | 02:01 PM
Fliptard's Avatar
Yea, you need a new headgasket.
Old Oct 3, 2012 | 07:53 PM
KtHaNxBai's Avatar
i hope thats the fix...
Old Oct 3, 2012 | 11:31 PM
dickdragon's Avatar
Don't forget to check head n block mating surface. Make sure it's nice n smoove!
Old Oct 4, 2012 | 12:32 AM
standy xsi's Avatar
if it was fine before you parked it up i dont see why it will be headgasket..
just take it for a 15 min drive before anything
also all the seals will be hard so you might loose a bit of oil and water, hapens to every car. you have to run them back in, especially valve seal's where old oil has been.
dont jump straight to headgasket and people stop saying it without testing
Atauto
Honda CR-V & Element
Aug 27, 2016 08:13 AM
codyweiss97
Mar 8, 2014 11:04 AM
blackmfoggie
Sep 7, 2007 07:34 PM
petrv
12
Jul 14, 2003 06:33 AM
Witty
Jul 7, 2003 06:12 AM
