Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
have other civics have this problem, too?
Old Oct 1, 2012 | 04:08 PM
norcali707's Avatar
Default have other civics have this problem, too?
Hi everyone I have a 2001 civic lx sedan and I have this cracking noise coming from the whole suspention... Each time I drive over a speed bump, I heard a loud crank sound from the front and rear wheels. I have replace the struts and some bushes but still got the noise... I have looked all under the car looking for loose bolts or bad parts but cant see nothing.... those anyone else have this problem with they civic?
Old Oct 1, 2012 | 07:06 PM
lazlong's Avatar
Default Re: have other civics have this problem, too?
Did you replace the bushing on top of the strut assembles when you replaced the struts? I found out the hard way and had to replace both fronts again. Also check motor mounts, all the bushings, and swaybar bushings and endlinks- if you have 'em.
Old Oct 1, 2012 | 09:20 PM
norcali707's Avatar
I did replace those bushing.. I just put in a rebuilt tranny and I replace the front motor mount... All the bushings do kinda look old, is it hard to replaces them?
Old Oct 1, 2012 | 09:32 PM
It Wasn't Me's Avatar
Control arm bushings? Not hard to replace if you have a press. Not really worth the price of having a shop do it, but you can at least check around. It might be cheaper to just buy new control arms vs. buying the bushings and having them replaced by someone else.
Sway bar bushings? Piece of cake to replace.
Old Oct 2, 2012 | 06:38 PM
norcali707's Avatar
this is normal for this part to be this loose....
Old May 1, 2013 | 05:47 PM
norcali707's Avatar
after replacing the sway bar links, I still have the cracking sound on my civic... It is driving me nuts!!!!!!!!
SIDreamer
11
Mar 1, 2011 05:25 AM
GunSamir
Oct 27, 2010 07:19 PM
Acura_DreamiN
Oct 22, 2008 06:21 PM
MulletManRockStar
Apr 11, 2005 12:18 AM
BrokeLude
Jul 27, 2004 07:50 AM
