Seeking Honda Wiring specialist
Old Oct 1, 2012 | 02:00 PM
traviscl's Avatar
Default Seeking Honda Wiring specialist
I have an offroad vehicle with a honda 3.0 V-6 2000 or 2001. I want to wire in a OBD scanner port. Does anyone know of anyone who is capable of doind this in the southern california or ventura county area?
Old Oct 1, 2012 | 03:38 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Seeking Honda Wiring specialist
Well that depends on what ECU/PCM is being used.
If the factory electronics are used, and the OBDII port is missing, it may have simply been cut off when the harness was installed. If this is the case, you will need to locate another '00/'01 harness to pilfer the pigtail, or replace the existing harness(if it has been excessively hacked).
If it is a stand alone type unit, it will more than likely just have a serial/usb port on the ECM for programming and monitoring with a laptop, then no real reason to have the OBDII specific port.
Kss
Sep 19, 2012 04:02 PM
higgunscrx
Sep 4, 2006 07:04 PM
b18c1EG21
Sep 20, 2004 12:58 AM
civic disobedience
Apr 14, 2003 06:21 PM
jeffrey
Jan 25, 2003 08:48 PM
