99 Accord Steering Wheel Control Problem
Old Oct 1, 2012 | 01:11 PM
Qlet's Avatar
Icon2 99 Accord Steering Wheel Control Problem
Hello, I am new to the forums. I have done some searching and can find no answer to this problem..The problem I am having is this:
I have a 99 Accord V6 Model with steering wheel controls. When the car had a factory radio in it the steering controls (I believe) worked just fine. Now I have had a high end nav radio installed at a local business I have used for years and years ( I don't believe they would lie to me as they are friends) I also had them install an interface so I could retain my controls. Now as soon as it was installed the volume controls barely work. Sometimes it will not respond at all and if you move the steering wheel a little it will work. The middle button between volumes works every time no matter what, but the strange thing is I will be driving and the middle button will be activated for no reason..example I will be driving and my CD will skip to the next track or radio will go to next preset. Sometimes it happens when I go over a big bump, but sometimes it happens on smooth roads.
The man at the place thinks it could be the steering wheel clock spring. I don't understand why it would start after this interface was installed. He thought maybe the interface went bad so he swapped it out 3 times to see.
My Cruise control work perfect and the SRS light is not on so I don't know what it could be.
Thanks for the help.
Old Oct 2, 2012 | 11:07 AM
Qlet's Avatar
Default Re: 99 Accord Steering Wheel Control Problem
Update: The audio place swapped out the interface for a completely different module and it is still doing the same thing.
Thanks for the help
Old Oct 13, 2012 | 07:32 PM
Qlet's Avatar
Does anyone have any input? I am really in a bind and would apprieciate it.
Thanks
Old Oct 15, 2012 | 05:01 PM
jdowen2's Avatar
Sounds like a poor wiring job. Loose connections or exposed wires that are touching when bumped.
Old Oct 15, 2012 | 05:54 PM
sightsandsounds's Avatar
I would ask the installer to Reinstall the radio its only fair.Or put in a new one, could be defective Radio. Or take it to another shop for opinion.
emasterp
Jul 20, 2009 07:35 PM
B_Something
Audio / Security / Video
Aug 8, 2007 04:38 AM
pmilnes
Mar 24, 2004 02:03 PM
