gsr swapped into ek build
So right now im driving a 1999 honda civic dx hatchback with the d series 1.6l 106hp very slow. ive done my research through honda tech and other forums and ive decided i want to swap a b18c1 ( usdm gsr ) with non lsd transmission. im wondering if the parts that i have will compliment the cams to its full capability and if im missing something or should change something then please give your opinion. And also just wondering what kind of hp and tourqe you can get with this kind of setup.
Gsr engine and tranny swap
Skunk2 tuner series stage 2 cams
P30 pistons
Skunk2 valvesprings and retainers
ITR Cluster
Skunk2 throttle body
Skunk2 intake manifold
Hondata S300
Tune
Cold air intake
Apexi n1 catback exhaust
Thanks for all the advice and knowledge!!
P30 pistons
ITR Cluster
Hondata S300
Tune
Cold air intake
I would look into a "Typhoon" Intake manifold. I have one on mine, basically a cheaper ITR mani. It's deff nice.
and you want an ITR clutser into a civic? not just a bolt in deal.
Itr cluster will not compliment the cams. However you didn't mention the most important compliment to the cams... Get some adjustable cam gears.
Ive heard for the tuner series cams that you didnt really need adjustable cam gears? wrong info maybe but just from what ive seen. if not the itr cluster any ideas on what else to put in that will handle the high rpm and bolt on a little easier. thanks fliptard for the intake mani idea ill look into it!
jdm009
Feb 10, 2014 06:17 AM
Havokgsr
Mar 30, 2003 07:50 PM
JDM CRX
Jul 1, 2002 09:48 PM
