00 Civic with bad piston rings...mechanic says to replace engine - need input
Old Sep 30, 2012 | 08:36 AM
rob_nordberg's Avatar
Default 00 Civic with bad piston rings...mechanic says to replace engine - need input
Hey guys,
So a while ago i came to you asking a question about my engine burning oil. You guys were right, it was the piston rings. My mechanic said its cheaper to replace the engine rather than go through and rebuild. Well, i don't know anything about engines so does that mean i just need a new head? I'm looking to spend probably no more than $700 for whatever i need and then i will get a price for installation. So what do i need, and what is the best i can do for this price?
Thanks!
Old Sep 30, 2012 | 08:40 AM
94EG8's Avatar
Seagull Management
Default Re: Again, with my engine...i'm replacing it
No, it means you need an engine. The head is part of the engine, you need the whole thing.
Old Sep 30, 2012 | 08:41 AM
my car is a 2000 Honda civic ex, forgot to mention that.
Old Sep 30, 2012 | 08:42 AM
redm3turbo's Avatar
pistons are under the head...so you need more then just a new head.
you need to tell us more info...what kind of car, what engine?
Most likely your best bet is low mileage JDM engine shipped over from hmotors
and about 600-1000 to have a shop install it.
redm3turbo's Avatar
double post.... sorry
Old Sep 30, 2012 | 08:44 AM
So am i screwed if i only have $700 for an engine?
Old Sep 30, 2012 | 08:46 AM
redm3turbo's Avatar
^ how handy with wrenches are you?
for 700 you could rebuild all OEM a d16y8...or buy a new low mileage jdm motor
thats with you doing all work though.
without that..yes, your in a bad spot
Old Sep 30, 2012 | 08:56 AM
I'm new with cars, so i'm gonna say that i'm better off buying a complete engine in this case.
Old Sep 30, 2012 | 09:07 AM
redm3turbo's Avatar
$700 is the cost of the engine. install is about 600-800
Old Sep 30, 2012 | 11:09 AM
92lxsleeper's Avatar
Hey guys,
Thanks!
if you are on facebook, join the groupe Octane Streets (based out of warwick, ri) and JDMASS (based out of mass) there are a few Y8's for sale under $200
Old Sep 30, 2012 | 11:48 AM
furious94ls's Avatar
with enough research you can get a D16y8 for about $500.
Old Oct 1, 2012 | 06:22 AM
kyden's Avatar
Default Re: 00 Civic with bad piston rings...mechanic says to replace engine - need input
the local junkyards are asking a lot of money for used motors for your car. i would try to find someone who has swapped and is selling their old motor.
i would probably rebuild the motor if all it needs is rings.
Old Oct 1, 2012 | 07:35 AM
Jhicks's Avatar
Old Oct 1, 2012 | 07:44 AM
kyden's Avatar
i must also mention, buying a used motor off someone is also a gamble. if you get one from a salvage yard, most of them at least have a decent warranty.
Old Oct 1, 2012 | 09:34 AM
fragmare's Avatar
Since when is it cheaper to buy a new engine than simply rering the pistons? You can probably get a set of rings for $50ish bucks per cylinder and a head gasket set for 100ish. Just get a car savvy buddy to come help you some weekend and pay him a case of beer lol
Old Oct 1, 2012 | 10:06 AM
kyden's Avatar
labor.
Old Oct 1, 2012 | 12:15 PM
B20DelSol's Avatar
Plus, Oil Pan Gasket, Timing Belt, Water Pump, T/B tensioner, Cam Seals, Drive Belts, Oil, Coolant, Connecting Rod Bearings, and Front Crank Seal. That is another $300 or so and of course, labor on top of that.
Engine Importers like Attarco in Richmond and Sacramento, CA have D-series engines with ~60-80K miles for $400-500 and a 6-12 month warranty. I would say its comparable with less labor going into getting another engine.
Old Oct 1, 2012 | 12:31 PM
kyden's Avatar
^^ well a basic timing belt replacement would have to be done on the replacement motor also.
Old Oct 1, 2012 | 05:04 PM
redm3turbo's Avatar
ive done the numbers, more then once. It always works out to just buy a low mile 30-45k engine then to get involved in rebuilding (especially if you aren't doing yourself)
Old Oct 2, 2012 | 08:04 AM
fragmare's Avatar
I'd only get the timing belt, drive belts, tensioner, and water pump if they were due for a change anyway. Cam seals come with the head gasket set (at least the Fel-Pro one). Oil Pan Gasket, Bearings and Crank Seal(s) are all dirt cheap on rockauto.com. Oil and Coolant are a given, I have that stuff sitting around my garage anyway.
broke-engine
Apr 7, 2017 12:48 PM
Yuta
Oct 19, 2015 04:27 AM
b16aman
Feb 5, 2004 12:09 PM
AJTEG
Jun 27, 2002 04:15 PM
tweekerz
May 21, 2002 02:43 PM
