94 Accord LX Dash/Interior Lights Wont Work
Old Sep 29, 2012 | 03:49 PM
BSmoov83's Avatar
Default 94 Accord LX Dash/Interior Lights Wont Work
Hey guys, I know this problem has been brought up here before and I've searched for solutions, but havent seen any threads with my identical problem. Here's the problem, followed by some background to help narrow it down.
1994 Accord LX (4 Door, Automatic Trans)
I do have an aftermarket stereo, but all wires and connections are sealed up and protected.
The Bad:
- My dash lights arent working. By that I mean the lights in my speedometer, fuel gauge, RPM meter, and temperature gauge. The lights above them are also out.
- My instrument lights are out. (The lights above my radio and the lights in my gear shifter).
- My dome light, wiper delay setting, and rear defroster do not work. (I'm told these are all part of the same fuse)
- My key is stuck in the ignition.
The Good:
- My AC and heating controls are functional. My clock, hazard lights, cruise control, and cigarette lighter also work just fine.
- None of my fuses are blown (in both the driver side panel and under the hood)
When I bought the car, the lights all worked just fine. Then they started to come on and off, and when I would bang on the top of the dash they'd stay on for a little bit, but eventually they went out and never came back on.
The Small Lights fuse also use to blow whenever I would replace the fuse and turn the lights on.
Today I tore apart the dash, checked all the bulbs and wires and everything looked to be in pretty good shape. Now the Small Lights Fuse no longer blows, but my dome light and rear defroster still dont work.
I've looked all over and cannot find a solution. I still have yet to get a new dimmer switch (the one with the adjustable ****) and that is my next step. Any other suggestions would be great!!
Old Oct 1, 2012 | 05:35 PM
BSmoov83's Avatar
Default Re: 94 Accord LX Dash/Interior Lights Wont Work
Problem Solved!!! (kind of)
I went to a junkyard and replaced the dimmer switch (next to the cruise control switch) and I now have dash lights, all except for the light behind the air control *****, the shifter, and the ashtray...most of which worked for a second but then went out, even after I changed the bulbs.
While I was at the junkyard I went ahead and picked up a new cluster anyway. The 97 I got it from had a nicer dash anyway.
However, my Rear Defroster, Dome Light, door chime, etc are still out. I figured out that the "Interior Lights" fuse is blowing almost the second I put it in. This is a 7.5 fuse under the hood. I plugged it in, heard a door chime for a second, then poof, the fuse blew.
I had the entire dash pulled apart and could not find a loose wire or loose connection anywhere. I've had everyone throw a schematic at me telling me to figure it out, but if I knew how to do that, I wouldnt be posting my problem online. Those things look like Japanese to me.
Old Oct 2, 2012 | 11:51 AM
h0p3l355dork's Avatar
Well you did some good troubleshooting. A fuse blowing right away means that there's a short somewhere in your electrical. That's where the hard part comes in, find the short, problem solved. Good luck
Old Oct 2, 2012 | 02:38 PM
bigbpatel's Avatar
looks like u hvae a wiring issue....i just got my 94 accord like a month ago and i have the same issue with my interior lighting, the control ***** cut on sometimes..im gettin the blue interior light swap figured id try and fix it then...if i figure anything out when i take my **** apart this weekend ill post it
Danigirll
Nov 18, 2017 07:14 PM
tlbounds
Mar 7, 2016 05:56 PM
calboi
Jul 4, 2009 08:52 PM
g8ts
Classic Hondas
Oct 27, 2008 04:05 PM
fleastang
May 26, 2006 03:38 PM
