1994 Honda accord lx
Old Sep 28, 2012 | 08:25 PM
blow1987's Avatar
Icon2 1994 Honda accord lx
I have problems starting the car at first the fuel pump wouldn't cut on so i put new fuel pump in and it started up once but couldn't get it to start back. Then i put new computer in it and it done the same thing started once and that was it anyone with suggestions? Im at a loss on what to do help needed please
Old Sep 28, 2012 | 08:28 PM
kuyaalland's Avatar
Default Re: 1994 Honda accord lx
Need more info. Idle? Cranking? Turning over?
Old Sep 28, 2012 | 11:27 PM
holmesnmanny's Avatar
Check your fuses. You may have blown a fuse.
Old Sep 29, 2012 | 08:59 AM
blow1987's Avatar
I can't get it to start now. When t would start after changing those parts it would crank once and run smooth it would idle right and everything but when i would cut it off it wouldn't start back i drove it the last time down the road and it died on me while driving just cut off didn't run rough or anything and the fuses are good done checked those first
Old Sep 29, 2012 | 09:01 AM
blow1987's Avatar
It will turn over like it wants to start but won't. New plugs wires new fuel pump new computer is all I've done
Old Sep 30, 2012 | 05:28 AM
Lost Again's Avatar
Fuel or spark?
When you turn the key to on, does the pump run for 2~3 seconds? You can listen for this or check the voltage at the pump.
Spray carb cleaner into TB - open the butterfly. Try to start it, does it run for a few seconds.
There are a few tests for spark that can be done as well.
Which is missing, let us know.
hometheaterman
Sep 13, 2012 11:34 AM
James Olmstead
May 21, 2012 07:26 PM
nova1370
Apr 30, 2012 07:07 AM
lawlerlaw
Nov 16, 2004 01:25 AM
hack3r
Apr 23, 2004 08:47 PM
