swap axles and camber kit questions
i have a jdm b16a swap with a ys1 trans in my 92 civic hatch and i wanna put new axels on it and i just need to know what axels i should buy since im getting brand new ones which car should i look up to order them? Also i have skunk2 camber kit on it the upper control arms and i need new ball joints and i was just wondering before i got into it if you can replace the ball joints on those camber kits or if you need to just buy a new upper arm? thanks for the help its much appreciated
And go to skunk2 and buy just the ball joint
Here u go
http://store.skunk2.com/suspension-t...ll-joints.html
Right axle can be for 1990-2001 Integra 5 speed. Doesn't matter if it's LS, GS-R, ITR, etc.
Left side axle will depend totally on what intermediate shaft you have - does the left axle inner joint have a male, or female end?
Also screw buying axles online. Your local O'Reiley's has brand new axles for $80.00 and have lifetime warranty. Normally I don't suggest local parts stores' junk parts, but you are always going to need axles, and quickly, if you have a lowered Civic.
