H22 Timing belt changing q's
Old Oct 17, 2002 | 08:13 AM
EK22Tim's Avatar
Default H22 Timing belt changing q's
I posted this in the HYBRID forum to no avail.. You guys are H22 experts here so..
Here goes. I'm changing the timing belt on my JDM H22.. I got the USDM 97 H22 belt, but I found out my motor is a 95, so its a 96 model year.. the #'s on the belt are like P13-004 on the CAR, and on the part they are P13-014... Are they the same length? I need to get this on, but it seems REALLY tight, even with the auto tensioner off.... Any help would be GREAT. thanks!!!
And how'd you keep the auto tensioner compressed when you installed it again? there's a special tool from Honda, but I know you guys didnt all buy one..
Old Oct 17, 2002 | 08:59 AM
satan_srv's Avatar
Default Re: H22 Timing belt changing q's (mitsuman90)
You could put on the H23 Manual tensioner for one thing, then you don't have the auto-tensioner problem and you can adjust it yourself
Old Oct 17, 2002 | 09:58 AM
apexii's Avatar
Yes the manual tensioner is a good idea, but for the auto the "tool" that secures it really consists of nothing. I will let you borrow if you promise to return.
The timing belt is a good question. I bought timing belts off a guy on PO a while ago, I don't know which # they are but i'm going to check tonight!
Old Oct 17, 2002 | 10:12 AM
EK22Tim's Avatar
Default Re: H22 Timing belt changing q's (apexii)
You have PM. I would REALLY REALLY appreciate that man. to you!
Still stumped on the belt #'s though.. Anyone out there know if they're all the same? once you remove the tensioner, shouldn't it be easy to change the belt, or is it a real tight fit?
Old Oct 17, 2002 | 10:19 AM
apexii's Avatar
No problem bud. I will also check on the timing belt #'s from my old ones and the new ones I have waiting to go on.
Old Oct 17, 2002 | 12:34 PM
kevie88's Avatar
The belts are interchangeable, I have the '014' on my car, and I changed from a '004'.. The last 3 digits in a honda part number are the part 'revision' or a supplier change ect. You can use the new belt FOR SURE.
Buy the tool to install the tensioner, it's the best way to go, it cost me like 8$ Canadian and I got it the next day.
[Modified by kevie88, 2:37 PM 10/17/2002]
Old Oct 17, 2002 | 06:53 PM
DarkJedi's Avatar
with the autotensioner off the belt should slip right in if aligned properly , i went to a honda dealer and talked a mechanic into letting me borrow his stopper tool for $20 as collateral.
Old Oct 18, 2002 | 04:15 AM
EK22Tim's Avatar
Default Re: H22 Timing belt changing q's (DarkJedi)
I don't know, the tensioner is off, it's a VERY tight fit.. Maybe I need to check alignment again. not sure..
Golding.racing
Feb 7, 2012 02:01 PM
speedracercmc
Feb 5, 2008 12:05 PM
H22ek4
Dec 13, 2003 10:28 AM
EK22Tim
Oct 17, 2002 08:24 AM
