jdm momo srs conversion help! :(
Old Sep 27, 2012 | 02:57 PM
PiZZaBoY7000's Avatar
Default jdm momo srs conversion help! :(
i tried doing a research couldnt find much info needed sorry if its a repost :S
i baught the jdm steering, my friends had told me its direct bolt on
i take out everything to put in the jdm one, i install the jdm clockspring and when i come to put in the jdm it doesnt fit, the hub is bigger then the usdm and it doesnt grab all the "teeth" from the column?!
what should i do help me please
Old Sep 27, 2012 | 05:13 PM
drummerdude's Avatar
Default Re: jdm momo srs conversion help! :(
I might as well say it, otherwise someone else will... vehicle details and what year did the wheel come off of?
Old Sep 27, 2012 | 08:34 PM
kchungb17a's Avatar
Sounds like you bought a CTR wheel. Those only work on EJ/EK (96-00 civic). You should have bought a DC2 ITR wheel. The easy fix is to put an EJ steering column onto your DC2/4 (I assume you have a 94-01 integra since you're in the forum).
Wiring it up may be a whole other issue though.
I'm thinking you should stop listening to your friend.
jonas
May 14, 2003 11:59 AM
itr-j
Oct 11, 2002 06:08 AM
jet
Sep 13, 2001 06:08 AM
