91 ef2 JDM D16A CEL wont go away
ok so i have a 91 ef2 and i droped a jdm D16A vtec motor from a 92-95 eg si it also came with p08 ecu and not the p28 ecu because the po8 only looks for one 1 wire o2 sensor and not a four wire o2 sensor (so i was told) so i bough the mil-spec harness form rywire to convert it to OBD1 so i could run the motor.. the harness i got im guessing is for a wire tuck and the o2 sensor wire was really f**king long... so everything was going grate drove it for like 2 months just fine and all of the sudden the wire got warped around the cv joint because the wire fell between the firewall and motor and tore it to sh*t luckily it wasn't that bad so i checked the harness and made sure that there was current going threw to the ecu with a multimeter and there was but the check engine light kept coming on after i reconnected the o2 sensor and it dosent come on right away... it comes on once the car is warm and u drive for about 15 min then the check engine light comes on... so i have tried everything to fix it i bought a new o2 sensor because the wire was coming out of it... i even called rywire and they said to bypas the harness and run a wire from the o2 sensor straight to the ecu and did that and the damn CEl still comes on.. so my question is could i have grounded out the wire and skrewd up the ecu so no matter what i do the check engine light is going to come on because its fried? has anyone ever dealt with something like this please help.. before i go buy another p08 ecu
Space different points about the problem out a bit.
Like this.
So we can clearly analyze the situation step by step.
1st question, why are you running a B16A on a D15b ecu? Sure it runs but why?
2nd. Did you verify cel is for o2 sensor and not another part of the harness to another sensor?
Like this.
oh ok i see wat ur sayin... its not a B16a its D16a and when i check the code its one quick blink withc means code one which is the primary o2 sensor
killerb7888
10
Oct 29, 2013 07:47 AM
sohc_ef2
Sep 29, 2012 05:34 PM
soledadcivicstd
May 12, 2010 01:38 PM
NatedoggAZ
11
Apr 15, 2004 11:30 AM
