Endlinks Question?
car: 99 integra 2 door GS
BWR subframe brace
F7 LCA's
oem sway bar
i Just want to know if an ASR sway bar will be worth changing too? also will the ASR sway bar work with my OEM endlinks?
is it worth buying ajustable endlinks?
thanks!!
BWR subframe brace
F7 LCA's
oem sway bar
thanks!!
What size sway bar?
In my opinon yes swapping to the ASR would be worth it. The BWR "brace" is not a brace at all.
I'm not postive on the endlinks, but I'm pretty sure they would work fine. ASR will be able to tell you.
For the adjustables, no it's really not worth it for a street car.
I have blox spherical adjustables front and rear, I ******* hate them! They are noisy as hell. There are times where it sounds like my car is going to fall apart.
IF you get adjustables, buy quality ones. F7, ASR would come to mind.
