Header/downpipe
Old Sep 26, 2012 | 01:03 PM
new_kid's Avatar
Default Header/downpipe
Looking for a good upgrade over the standard header/mani on the 94 jdm 2.2 vtec and all the tri-y ones i have seen need the crossmember notched or a traction bar fitted, does anyone know of any decent setups and were i could get one please
Old Sep 26, 2012 | 04:39 PM
crazes's Avatar
Moderator
Default Re: Header/downpipe
basic 1 would be a megan or dc header that are available for replacement. You can spend some money and get a custom 1 made that wouldnt require any adjustments but that probably would not be financially smart to do.
Old Sep 26, 2012 | 04:58 PM
bigblockh22's Avatar
If your looking to upgrade your header, your gunna have to get an aftermarket crosmemeber to make the header worth it. Megan or Dc headers dont produce enough power compared to other aftermarket headers. better off just leaving the factory header.
Old Sep 27, 2012 | 06:41 PM
BB1 H22A LUDE's Avatar
It may cost more and be more work to fit but if your looking for more power you need to spend the cash and the time on a decent header. Converting from stock to hytech-replica with 2.5' exhaust cost me a fortune in the end (flanges, rear 2.5' olive, steel piping, argon gas on top of header and exhaust) but the end result was well worth it. Shifted the power band up by around 400rpm, making peak HP at 7200rpm instead of ~6700-6800rpm and hp flat lines till 7700rpm.
Just notch the cross member, DIY job:
Old Sep 28, 2012 | 04:53 AM
yroachy's Avatar
I believe the vibrant header does not need crossmember notching.
Old Sep 30, 2012 | 02:42 PM
3rdtimecharmer's Avatar
10 Year Member
LOGIC racing.
Old Oct 1, 2012 | 07:39 AM
EndlessHonda's Avatar
Just notch it, it isn't that hard. Most power producing headers require the notching because of bigger pipeing.
Old Oct 4, 2012 | 01:12 PM
slowredsol's Avatar
I will have to agree with 3rd time....the logic motorsports headers are really nice and are only $400 brand new.
Old Oct 4, 2012 | 06:12 PM
10 Year Member
makes more power over BISI and RMF. for h2b swaps and h22/F20b motors alone, that is. not sure for any other motors.
doing a F2B swap in my integra and thats my choice of headers after i get it running.
blu3g
May 25, 2005 02:26 PM
93Civic_hb
29
Apr 24, 2004 07:48 AM
H23A1LUDE
Aug 29, 2003 04:13 PM
