a few questions regarding coil overs n tail lights
hello i have a 95 accord v6..
im wondering if the tail lights for the 4cyl are the same for the v6..
also im wondering if i can use coilovers that are for the 4cyl for my v6..i heard i can but im not to sure...oh can i use the lowering spring for a 4cyl for a v6?..because the coil over set is expensive..thanx
With regard to your second question, yes the lowering springs will physically fit in the strut. Just realize that the V6 is heavier than the F-series, which you should consider when selecting the spring rate and damper for your new setup. Yes a full coilover set is more expensive than buying just springs, but you are going to have to buy a higher rate damper anyway if you get stiffer lowering springs. Unless of course you want an underdamped = bouncy ride.
abercrombemonkey
Suspension & Brakes
Oct 1, 2005 08:23 AM
