Wheels845 for sale thread come one come all!!
$900 I got a full b series turbo kit with extras
60 trim turbo
All the piping
wastegate 10lb spring
blow off valve
manifold
downpipe
1000cc rc injectors
intercooler
Turbo timer
boost controller
all gauges
gm 3.5 bar map sensor
3" inch custom hi power apexi exhaust system*
Dr20's on falken drag radials 90% tread left $450
$350 Tuner fx racing seats w/
5 point race belts and
typer floor mats
Tein springs on kyb shocks $250
Front spindles $200
Upper control arms
Lower control arms
Calipers
Rotors
Pads
Dc2 Complete Rear disc conversion :$250
E brake cables
E brake handle
Rear calipers
Rear rotors
Rear pads
Stock lcas
Type r wing $100
Full race Msd ignition: $350
Spark plug wires
Msd coil
Msd igniter
Msd distributor cap
Halo projector headlights with hi and low h.i.ds $180
Type r tailights $sold
Momo steering wheel with hub $80
1996 acura integra gsr Shell non rolling $500
K20 typer ecu (no immobilzer needed)$150
K20a dc5 flywheel $80
K20a dc5 throttle body w gasket$70 (68 mm)
K20a2 type s throttle body w gasket$70 (63 mm)
K20a dc5 stock motor mounts $60
Dc2 typer brake master cylinder $50
Dc2 typer clutch master cylinder $50
Dc2 typer clutch slave cylinder $50
Gsr rear wiper assembly $50
Rear t brackets$30
Xenon 94-01 acura integra mirrors $50
Lanzar 2,000 watt vibrant amp
Model - Vibe 268*Two-channel
Hi/Lo pass crossover $80
2 12" pyle subs in a box $60
17" adr rims and tires $160
If anything else is needed please contact 1347-352-1296
60 trim turbo
All the piping
blow off valve
manifold
downpipe
1000cc rc injectors
intercooler
Turbo timer
boost controller
all gauges
typer floor mats
Front spindles $200
Upper control arms
Lower control arms
Calipers
Rotors
Pads
E brake cables
E brake handle
Rear calipers
Rear rotors
Rear pads
Stock lcas
Type r wing $100
Spark plug wires
Msd coil
Msd igniter
Msd distributor cap
Rear t brackets$30
GI8U2racing
Mid-Atlantic (Sales)
Nov 7, 2012 10:12 AM
WHEELS845
Oct 21, 2012 05:26 AM
