NEED A QUICK ANSWER ABOUT VACUUM LINE ON REAR RADIATOR HOSE!!
Old Sep 25, 2012 | 06:51 PM
97accordbuildlx's Avatar
Default NEED A QUICK ANSWER ABOUT VACUUM LINE ON REAR RADIATOR HOSE!!
i recently took off my engine head and in the process i cut a few vacuum lines to kind of remind myself to replace them later since they were brittle. long story short, i have the head back on the engine. i thought i replaced all the lines i cut. When i went to fill up my radiator, i heard fluid leaking onto the ground. turns out it was leaking from a cut rubber vacuum line on top of the Rear Radiator Hose mount,.......Its still dripping fluid, need to figure out where it goes.
since it has fluid in it, im not trying to connect it to the wrong place.
a quick answer would be greatly appreciated. i have a screw in it for now but i need to fix it.
its an h22 btw.
Old Sep 26, 2012 | 05:30 PM
fcm's Avatar
fcm
Old Fart
Default Re: NEED A QUICK ANSWER ABOUT VACUUM LINE ON REAR RADIATOR HOSE!!
If it is leaking fluid it is not a vacuum line.
Can you post a pic of the leaking line.
Is it 2, 3 or 4... http://www.hondaautomotiveparts.com/...E+%28+95-97%29 if it is a 97 Accord? 94
Old Sep 26, 2012 | 08:03 PM
hey, thanks for the help. my description was terribly off, but it was the thermostat housing coolant line that attaches to the intake manifold.
i got it fixed tho but thanks anyways
Moorehonda
Jul 12, 2015 05:02 AM
97accordbuildlx
Sep 26, 2012 12:01 AM
Yamabu
Sep 21, 2012 08:24 PM
96WhiteOnBlack
Apr 5, 2007 08:01 AM
