02 accord coupe very bumpy ride
Old Sep 25, 2012 | 04:48 PM
NickVH's Avatar
Default 02 accord coupe very bumpy ride
First post, sorry for the long story but I'm stuck. I have an 02 accord coupe v6 ex with 144,xxx miles. For a while I had a slight knocking while making left turns, as I commute on a very bump road it happens a lot. Fast forward, took it to the honda dealer they couldn't figure out what was wrong, ended up going to a local wheel works and they found out that my front right strut was blown. Talked to me into replacing all struts and mounts and the front right wheel bearing. Definitely noticed suspension performance was better, but I still had the knocking. Came back to wheel works and it turns out I the front right control arm had quite a bit of play in it. They fixed that and no more knocking, very glad. But now I still have a really bumpy ride, almost seems to be coming from more the left side, but sometimes in the center, especially when going over potholes, etc. They said the front left had no play in it. Question is: why would I still have a very bumpy ride if I replaced all struts, front right wheel bearing and front right control arm. Recommend replacing the front left control arm as that seemed to help the bumpiness from the right side? Could it be a motor mount and/or transmission mount? Any help would be gladly appreciated, thank you everyone!
7thAccord
Dec 20, 2012 09:53 AM
turbolsvtecej1
Aug 4, 2012 08:27 AM
kornfox
Dec 12, 2007 06:27 PM
conker
Sep 24, 2006 06:17 AM
