1998 acura cl 2.3l brakes
Hi Im new to the site but not hondas. I just want to know if I can put twin piston calipers off of an 2005 honda odyssey and v6 rotors on my 1998 cl 2.3? It looks like they might if I use my bracket. Any suggestions please.
Are your cailpers mounted upsidedown? The legend calipers have different bore sizes and are mounted in a trailing configuration.The CL is mounted in a leading configuration. I just didn't want to spend all the money on NSX calipers. I really need the help of the brakeman on this site. Thanks. Still looking.
The 2005 Odyssey and the Acura Legend both use 28mm rotors, and I think the V6 uses 23mm ones. So this would be like running pads with 5mm wear. OK as long as you change them out on a regular basis. But it would be better if you could find some 28mm rotors with the right hub diameter and the right depth.
Also, there are some good threads on brake applications on this forum. They really helped me when I made some conversions.
Superorb
Mar 24, 2003 01:37 PM
