Reving Issues afer auto to manual trans swap
Old Sep 25, 2012 | 02:39 PM
260zshooter's Avatar
Default Reving Issues afer auto to manual trans swap
I have a 92 SI that I recently swaped a auto trans for a 5 speed. Trans and hydraulics went in withour a hitch. I am able to start the car, but it will not rev over 2000 rpm. The service egine light is flashing codes 7, 41 and 14. I have replace the IAC valve, TPS switch, map sensor, ECM (twice) fuel pump and heated O2 sensor. I have removed and checked the entire engine harness and the problem remains. The car acts like it is hitting the rev limiter, if it has one. Did I miss something on the trans swap? The car shifts just fine.
Anyone got any ideas?
Old Sep 26, 2012 | 09:38 AM
Default Re: Reving Issues afer auto to manual trans swap
Do I need to unplug the auto trans computer?
Old Sep 26, 2012 | 12:30 PM
afrotec's Avatar
Yeah, unplug it, you don't need it anymore my brotha - you're freeeeeeeee
Old Sep 26, 2012 | 05:01 PM
bigblockh22's Avatar
which ecu are you running you might not be able to run the automatic computer now that you did the swap..
yukushi
Mar 11, 2013 06:12 AM
Flynt
May 4, 2012 07:18 AM
