i got a 89 honda crx wiring problem i need HELPP
Old Sep 25, 2012 | 03:02 AM
hatchydohczc's Avatar
Icon2 i got a 89 honda crx wiring problem i need HELPP
I got my 89 crx and I need help idk which wiring harness I should use cuz I read some articles and it says u can u the HF and I read others and it says that u can use the si I don't understand I need help please somone
Old Sep 25, 2012 | 04:08 AM
dephtone's Avatar
Default Re: i got a 89 honda crx wiring problem i need HELPP
What trim is the car currently? DX I assume?
Use your existing wiring harness, convert the car from DPFI to MPFI, below is a site that will help you with the conversion.
http://www.b20vtec.com/forums/techni...-diagrams.html
Good Luck!
You cannot use a HF engine harness as it will not plug in to your cabin harness unless you plan on pulling the dash and replacing that harness as well.
All of this is under the assumption the car is a DX.
ByonSho
Feb 2, 2010 01:13 PM
TheDelSlo
Oct 7, 2005 12:39 PM
Import-Style.de
Oct 29, 2004 02:15 AM
d16z6crx
Jul 5, 2004 09:25 PM
DOHC_EF
Oct 12, 2003 05:56 PM
