integra keeps losing battery power
I have a 94 integra with a b18c, and i recently changed my alternator and battery but my battery still keeps losing its "juice" and i have no idea what it could be, someone please help!!!!
Are you saying that batt. goes dead, [loses power] when siting overnight or for long piriods of time without running?
Or do you mean it loses power when driving, [engine running]?
If it is the first, goes dead overnight, you have a "parasitic drain" or a bad batt.
You can use a 12V test light or a multimeter to test for parasitic drain...
https://honda-tech.com/forums/showth...drain+test+fcm
If it is the second, the alt./batt. light should be on as the alt. is bad.
A charging system load test should be done, free at most batt./alt shops. 94
It goes dead while motor is running...
I checked the alternator just now, and it is loose and so is the alternator belt..
And the battery light doesnt stay on but it flashes
I will do the charging system test
Thanx for the input
Thanx for the input
If it goes dead while driving it is defs something with alternator.
Crossbreeder
Feb 5, 2010 07:36 AM
