Used ITR Shocks vs. Koni yellows
Old Oct 17, 2002 | 05:18 AM
Clutch784's Avatar
Default Used ITR Shocks vs. Koni yellows
I have the chance to buy some used ITR shocks and Ground control coilovers for $275. Do you think that the ITR shocks would be able to function properly if I dropped my integra ~2"? The guy trying to sell them said that the ITR shocks would work very well w/the coilovers. Is this a better deal than buying a new set of Koni yellows and Ground controls for ~$950? I need some help! Thanks.
Old Oct 17, 2002 | 05:25 AM
Neo's Avatar
Neo
Default Re: Used ITR Shocks vs. Koni yellows (Clutch784)
what are the spring rates that will come with the GC coilovers? If they're over 275#s (or thereabouts) then you'll be exceeding the spring rates on a stock ITR and, therefore, exceeding what the shocks were built to handle. This will cause the shocks to wear out faster, as will dropping the car ~2"
Koni yellows are a great shock (I've got them and them), but the off-the-shelf variety can handle spring up to about 450#s. Above that many would suggest getting them revalved to handle the stiffer spring rates, otherwise they won't last as long before needing a rebuild.
Old Oct 17, 2002 | 06:58 AM
Rezon's Avatar
ITR shocks require ITR lower control arms in the rear
Old Oct 17, 2002 | 07:02 AM
IN VTEC's Avatar
Koni's over the ITR shocks any day.
Old Oct 17, 2002 | 07:17 AM
TypeRdude's Avatar
The rear shocks won't fit without converting your lower arms at the very least. $950 for yellows and ground control? too much. We sell both for $838 plus shipping.
Yellows: http://www.diabloautosports.com/prod...roducts_id=300
Ground control for Koni: http://www.diabloautosports.com/prod...roducts_id=628
Order online 24hrs a day or call 925-371-7222 mon-sat 10am-7pm :D
m!ke
Suspension & Brakes
Jun 24, 2011 04:45 PM
alex_s817
Suspension & Brakes
May 3, 2006 07:09 AM
silvlude
Dec 29, 2002 11:35 PM
98R-1144
Oct 29, 2002 01:18 PM
Amuse9
Oct 22, 2002 06:34 PM
