Turbo ef filter fitment
Old Sep 24, 2012 | 05:37 PM
JDMmadness's Avatar
Default Turbo ef filter fitment
So im trying to figure out my best route with a air filter for my turbo b16 ef.As of right now im just running a 6in standard filter but its tight in space because its where my coolant resivor use to be,and its also hitting my hid. the only thing i can do is hang a longer filter or same size down the hole putting the intake filter in my wheel well.
but will i have issues with sucking in water?
and how would it be if i routed it in the well,and positioned it as high up as possible?
pic
(this isnt the filter im running the one i have hits everything and it a k&n)
just showing pic for location
lmk whatcha think i should do
Old Sep 24, 2012 | 08:33 PM
Charlie Moua's Avatar
Default Re: Turbo ef filter fitment
fresh air to the turbo does make more power BUT honestly i wouldn't worry about it.
I'd get a better manifold for more power
Old Sep 25, 2012 | 02:30 AM
JDMmadness's Avatar
not really trying to get more power just trying to see if its to risky to put the filter in the wheel well to get it away from hitting my hid
Old Sep 25, 2012 | 02:53 AM
grumblemarc's Avatar
The Grumpiest
It's baffling me as to why you don't get a smaller filter instead of that huge one.
Old Sep 25, 2012 | 04:30 AM
BLU CIVIC's Avatar
Track Advocate
ditto. k&n make a lot of different sized filters and it took me almost no time to find the exact size and shape I needed. it looks like if you get a smaller filter you should have no problem mounting it to the turbo or making it fit w/o having to route it all over the place.
Posted from Honda-tech.com App for Android
Old Sep 25, 2012 | 05:21 AM
can you mount your HID else where?
I've seen guys mount them on the underside of the chassie, it would be fine as long as you do run splash sheild.
Old Sep 25, 2012 | 07:06 AM
mayfly's Avatar
how about a hks filter?
Old Sep 25, 2012 | 07:34 AM
BLU CIVIC's Avatar
Track Advocate
from what I read, real HKS filter is hard to come by and the fake ones are a hit or miss
Old Sep 25, 2012 | 07:46 AM
wantboost's Avatar
Who is Mr Robot?
most of the hks foam filters (real or fake) all eventually break down and turn into compressor wheel cannon fodder...
Old Sep 25, 2012 | 09:05 AM
mayfly's Avatar
ouch sounds nasty, never ran one.
but i have used wire mesh with no issues, but that wasn't a daily either
Old Sep 25, 2012 | 10:07 AM
VTEC+Mini's Avatar
I wish I had that kind of space to work with.
Old Sep 25, 2012 | 10:52 AM
Ben Huynh's Avatar
For what it's worth, we have this filter on clearance:
http://www.knfilters.com/search/prod...x?prod=ru-3700
Old Sep 25, 2012 | 02:34 PM
JDMmadness's Avatar
It's hitting hid bulb, if I mount it right off the turbo it will be just as low as the wheel well, and there isn't as much room as it looks had to squeeze the filter in which is kinda crushing it
Old Sep 26, 2012 | 06:20 AM
The Grumpiest
Get. A. Smaller. Filter.
Old Sep 26, 2012 | 04:53 PM
JDMmadness's Avatar
No one thinks if I got with a smaller filter it will be a restriction? Im certain it will which is why I'm running a 6in,
Old Sep 26, 2012 | 05:06 PM
wantboost's Avatar
Who is Mr Robot?
no....
Old Sep 26, 2012 | 05:25 PM
The Grumpiest
Im certain it will...
Really? Please provide the data you base that claim off of. Otherwise you're just guessing.
Get the smaller filter. I HIGHLY doubt you're at any kind of power level that would cause any filter to be a restriction.
Old Sep 26, 2012 | 06:14 PM
JDMmadness's Avatar
Using to small of a filter could cause a inlet restriction which would lead to excessive exhaust temperatures leading to turbine housing cracking and scaling or even turbine wheel failures.
What would be an ideal size that wouldnt cause a restriction? Making 330whp 230tq
Old Sep 26, 2012 | 07:24 PM
TheShodan's Avatar
Moderator
Just the fake ones.. Not the real ones. I've used the real ones for years.. Never a problem.
Old Sep 26, 2012 | 08:19 PM
wantboost's Avatar
Who is Mr Robot?
running a "normal" sized k&n filter won't be am issue...... esp. at 330hp
the restriction is only a few inches of vacuum, not enough to matter
Old Sep 27, 2012 | 02:27 AM
JDMmadness's Avatar
what do you consider a normal size?
Old Sep 27, 2012 | 02:35 AM
The Grumpiest
Smaller than what you have. Get rid of that Spectre/Ebay filter.
You're getting on my nerves with this topic.
Old Sep 27, 2012 | 03:48 AM
rich7777's Avatar
^^^ We need to make you a mod....
Old Sep 27, 2012 | 11:44 AM
JDMmadness's Avatar
If you could read I'm running a k&n not the one pictured
Just saying...
Old Sep 27, 2012 | 01:04 PM
BLU CIVIC's Avatar
Track Advocate
Just saying...
and we keep saying change the filter
this is the filter i'm using and will probably work for you
2-1/2"Flg, 3-1/2"Od, 6"H
