90 crx b16 wont start
Old Sep 24, 2012 | 11:26 AM
hasty91ef's Avatar
Default 90 crx b16 wont start
I just swapped a b16 into my crx and I can't get it to start. I got a monotech wiring harness, new dizzy, new starter. I am using a pr3 ecu. I know it is getting fire and there's fuel going to the fuel rail. The timing is good. I'm not sure what I need to check now.
Old Sep 24, 2012 | 11:40 AM
RanCRX's Avatar
Default Re: 90 crx b16 wont start
Some actual info on what it's doing might help a bit. Like is it turning over but not starting? If it is, is it a slow crank or a very fast crank?
Does it not make any sound at all when you turn the key to run? Hear the Relay click? Hear the fuel pump purrrrrrr?
Old Sep 24, 2012 | 02:33 PM
hasty91ef's Avatar
It is turning over at a normal speed but not starting. The fuel pump is working because I took the return line off and got plenty of flow.
Old Mar 10, 2013 | 05:09 PM
L.D. built's Avatar
Inthat case sounds like electronic issues maybe timing not at proper state, make sure everythings plugged in then proceed with checking the ecu if that does not revive it. If you fixed already what was the issue? Thanx!
ERKK
85
Apr 3, 2009 11:34 AM
smokincrxwannabe
Mar 14, 2008 06:24 PM
Bump
Aug 30, 2006 04:50 PM
FUP23
Jun 30, 2002 01:57 PM
